Wired Intelligent Edge
Converting SFPs from stacking to uplink in 2500
  • 1.  Converting SFPs from stacking to uplink in 2500
    Posted Jan 07, 2015 10:13 AM
    How to convert SFP3 & SFP4 from stacking to uplink in S2500
  • 2.  RE: Converting SFPs from stacking to uplink in 2500
    Posted Jan 07, 2015 10:15 AM
    3+4 are not stacking ports out of the box. Did you change them?
    The command is
    Delete stacking interface
  • 3.  RE: Converting SFPs from stacking to uplink in 2500
    Posted Jan 07, 2015 10:18 AM
    No I didn't change them These ports can be used as uplink ports or a combination of two uplink ports and two stacking ports. By default, Ports 0 and 1 are configured as uplink ports and Ports 2 and 3 are configured as ArubaStack ports. The ArubaStack ports are indicated by a box around the port number. These port assignments can be changed to meet your configuration needs from the CLI.
  • 4.  RE: Converting SFPs from stacking to uplink in 2500
    Posted Jan 07, 2015 10:22 AM
    You're right. Fingers moving faster than the brain this morning :)
    Use the commands above.
  • 5.  RE: Converting SFPs from stacking to uplink in 2500
    You are correct, the 2500 has 3 and 4 as stackign and 1 and 2 as normal uplink ports.  Try the commands above andyou should be able to convert 3 and/or 4 to normal uplink ports.
  • 6.  RE: Converting SFPs from stacking to uplink in 2500
    Posted Jan 07, 2015 10:23 AM
    I think Cappalli hasn't had his coffee yet this morning so he didn't correlate SFP3 and SFP4 to mean the latter two ports of the uplink (0/1/2 and 0/1/3).
    Clembo has provided the proper instructions on converting the ports to normal uplink ports.
    Best regards,
    Madani
  • 7.  RE: Converting SFPs from stacking to uplink in 2500
    Posted Jan 07, 2015 11:09 AM
    Thanks All,
    it worked
    I have another question
    I have 2 Corinex powerline adapters that I use to connect 2 points as there no is way to install any cable
    When I connect them to any 2 switches or laptops they work fine, but when I use them between 2 Aruba switches S1500 they don't work.
    So I think that there is something which block their traffic
    Anybody can help??
    Thanks in advance
  • 8.  RE: Converting SFPs from stacking to uplink in 2500
    Posted Jan 07, 2015 12:10 PM
    When you connect these on S1500, even port LEDs won't glow ?
    or, just that traffic is not passing ? In that case can you check one of these port has moved to STP blocking state (show spanning-tree)
    -Vinay
  • 9.  RE: Converting SFPs from stacking to uplink in 2500
    Posted Jan 09, 2015 10:53 AM
    Yes, the led is on and the traffic is blocked And when I disabled the spanning the port turned down How can I permit traffic in this case?
  • 10.  RE: Converting SFPs from stacking to uplink in 2500
    Posted Jan 11, 2015 12:00 AM
     It is strange that disabling STP brings down the link. STP doesn't control physical link/port properties.
    Now, With ports connected on S1500 with Corinex, and STP enabled (spanning-tree mode mstp),
    Can you dump the o/p of  "show interface gigabitethernet <x/y/z>" for ports on both S1500s ?
    And, when you say  "When I connect them to any 2 switches they work fine"
     - which switches are you refering to ?
    Also, to confirm the connectivity, is this how they are connected ?
    S1500-ONE {GE-0/0/1} --------- [Corinex adapter]------------ {GE-0/0/1} S1500-TWO
    -Vinay
  • 11.  RE: Converting SFPs from stacking to uplink in 2500
    Posted Jan 11, 2015 09:35 AM
    The link was done due to another issue
    But when I convert it to PVST, everthing worked
    But do we have a way to keep the MSTP and unblock the traffic
  • 12.  RE: Converting SFPs from stacking to uplink in 2500
    Posted Jan 11, 2015 02:20 PM
    As we know PVST runs seperate STP instances per VLAN, whch makes some ports in "Forward" state in some VLANs & blocking in others, hence we can achieve kind of load-balancing of traffic
     Similar thing can be achieved in MSTP as-well.
     By default when you enable MSTP, only one 'instance' is running which spans on VLANS on the system.
      For better load-balancing of traffic, you can create multiple MST "instances": via something called as "instance VLAN mapping"
      This needs bit planning & deciding a root-bridge for each of those instances for "optimal" topology.
    Sample config like below needs to  be configured on all the switches in your topology
    (IDF-1) (config) #mstp
    (IDF-1) (Global MSTP) #region-name REG-1
    (IDF-1) (Global MSTP) #instance 0 bridge-priority 16384
    (IDF-1) (Global MSTP) #instance 1 bridge-priority 32768
    (IDF-1) (Global MSTP) #instance 2 bridge-priority 16384
    (IDF-1) (Global MSTP) #instance 1 vlan 100,200
    (IDF-1) (Global MSTP) #instance 2 vlan 300,400
      Above config makes VLAN 100,200 as part of MSTP "instance 1", and so on....
      And bridge-priority needs to be varied on other switches. In short, Bridge-priority (lower) decides which switch will be root-bridge for specific instance, (Refer MAS documentation for more details...)
  • 13.  RE: Converting SFPs from stacking to uplink in 2500
    Posted Jan 07, 2015 10:17 AM
    To convert a stcking port to uplink, run the following:
    delete stacking interface stack <module/port>
