Network Management
copy configuration from switch hp1920 to another
  • 1.  copy configuration from switch hp1920 to another
    Posted Jul 30, 2017 11:47 AM
    Dear Freinds
    can any one tell me how to copy configuration from switch hp1920 to another , i made backup of configuration for .cfg and .xml files and i restored in the other switch and saved and i rebooted the device but no vhange happed , also i used cli but i didnot found option for this model of switch.
    can any one help me to solve this issue...
    thanks alot..
  • 2.  RE: copy configuration from switch hp1920 to another
    Posted Aug 17, 2017 12:28 PM
    Hi Ameen, If you haven't already figured out the way to do this,
    you can possible copy the current configs to a tftp server, then copy it back to the new switch to the right location. I believe you can try copying the copied config to the running config, then reboot.
