copy controller configuration
  • 1.  copy controller configuration
    Posted Mar 12, 2013 06:02 AM
    We have a 3400 series controller, and we want to upgrade to 3600 . If there a way to copy all the configuration from 3400 to 3600 including network configuration(VRRP,vlans ect) .
    #3400
    #3600
  • 2.  RE: copy controller configuration
    Posted Mar 12, 2013 07:56 AM
    you can backup the flash from the old controller and restore them on the new controller.
    The Below KB article should help you
    https://arubanetworkskb.secure.force.com/pkb/articles/HowTo/R-234
  • 3.  RE: copy controller configuration
    Posted Mar 13, 2013 05:35 AM
    Dear Vinod,
    Thanks for your response and suggestion . Will the flash contain license information . If i copy flash from 3400 to 3600 will it copy licenses too .
  • 4.  RE: copy controller configuration
    Posted Mar 13, 2013 01:14 PM
  • 5.  RE: copy controller configuration
    Posted Mar 17, 2013 02:03 AM
    Thanks, will this work if we want to copy the exact configuration from 3400 to 3600 controllers ?
  • 6.  RE: copy controller configuration
    Posted Mar 17, 2013 02:15 AM
    well, i never tried it but i think yes with a little adjustment in ports and ip configuration.
    make sure you try it first before fully implement it.
  • 7.  RE: copy controller configuration
    Posted Mar 13, 2013 01:15 PM
    you need to copy the licenses to the flash first. find the export/import license under controller configuration -> licenses
    though, i think the licenses is bound by the SN of the controller.
  • 8.  RE: copy controller configuration
    Posted Mar 18, 2013 01:53 AM
    If you are paranoid (like me), you might want to do a "show ap active" and grab a list of the connected APs.
    http://www.arubanetworks.com/techdocs/ArubaOS_61/ArubaOS_61_CLI/showap.htm
    If on the same L2 network, they should all come back on okay.  But if there are problems (different L2 etc), then you at least have a quick cheat sheet of which APs might be looking for a home.
