AOS-CX Switch Simulator
Copy SFTP doesn't work on aruba 2530 switch
This thread has been viewed 21 times
  • 1.  Copy SFTP doesn't work on aruba 2530 switch
    Posted Jun 07, 2023 11:48 AM
    Hi everyone
    I have an SFTP/SCP-Server running with the ip x.x.x.x and I try to back up my startup-config of the Aruba switch (HP J9777A 2530-8G Switch)  with Image stamp: YA.16.10.0021 onto the SFTP-Server. I configured the user Cisco with a password on the SFTP-Server.
    Ports 21 and 22 are open on our firewall and on the local firewall of the SFTP server.
    When I try to back up my startup-config on my HPE 5130 Comware with SCP it works.
    On the Aruba switch, I get the error:  sftp: Request failed
    It also never asks for a password.
    I use the command:
    copy startup-config sftp Cisco@x.x.x.x port 22 test_aruba.cfg.
    What am I doing wrong?
    Thanks in advance for any advice!
    Best Regards
    Dario
  • 2.  RE: Copy SFTP doesn't work on aruba 2530 switch
    Posted Jun 08, 2023 04:45 AM
    Hi, this is the Aruba CX simulator community
    You could try something like:
    copy startup-config sftp user Cisco 10.1.1.1 port 22 test_aruba.cfg
    If you use ? at command line you get help faster than asking here ;-)
    Arne Opdal
  • 3.  RE: Copy SFTP doesn't work on aruba 2530 switch
    Posted Jun 09, 2023 02:42 AM
    Hi Arne Opdal
    Thank you for your input!
    It doesn't make a difference. I still get the same error.
    And I know what the ? does. ;)
    The options from copy startup-config sftp ? are:
    • HOST-NAME-STR         Specify hostname of the SFTP server.
    • IP-ADDR               Specify SFTP server IPv4 address.
    • IPV6-ADDR             Specify SFTP server IPv6 address.
    • user                  Specify the username on the remote system.
    • USERNAME@IP-STR       Specify the username along with remote system information (hostname, IPv4 or IPv6 address).
    I see on the network firewall that the allowed rule has been hit.
    So something is happening. Do you know by chance how to see the logs for port 22 in the eventviewer on the Windows Server (functioning as a SCP/SFTP-Server)?
    I want to get more information on the problem.
    Do you have any other ideas?
    Dario
  • 4.  RE: Copy SFTP doesn't work on aruba 2530 switch
    Posted Aug 02, 2023 03:28 PM
    Hello, I am using the same switch and I am receiving a general error when I try to use SFTP. Did you find any fix for it?
  • 5.  RE: Copy SFTP doesn't work on aruba 2530 switch
    Posted Sep 12, 2023 09:22 AM
    Hi miluxuad
    We clearly know now that it is a routing problem. On some location it works with these Aruba switches, because there is a correct, different routing path.
    I don't know if this will help you.
    Best regards
    Dario
  • 6.  RE: Copy SFTP doesn't work on aruba 2530 switch
    Posted Aug 03, 2023 02:25 AM
    So as already pointed out, this is not correct community for ArubaOS-S switches.
    Did you enable sftp server on the switch?
    Use "ip ssh filetransfer" to enable it.
    Best, Gorazd
    Gorazd Kikelj
    MVP Expert 2023
