Copying regions in VisualRF, AMP 8.0.4
  • 1.  Copying regions in VisualRF, AMP 8.0.4
    Posted Nov 06, 2014 11:43 AM
    Very much enjoying some of the new features in AMP 8.  Filtering could be a little bit better, but overall a great improvement.
    I've noticed that VisualRF no longer includes the option to create a region & copy it to the upper floors of a buidling.  That, in combiniation w/ the create walls around the region was a very useful feature.
    Is there any way of getting that back?  I thought I read that there is an option to revert back to the non-HTML5 version of Visual RF?
  • 2.  RE: Copying regions in VisualRF, AMP 8.0.4
    Posted Nov 06, 2014 12:22 PM
    The duplicate feature is on the to-do list for the HTML5.  In the meantime, you can revert back to the Flash version, perform the duplication effort, and then return to HTML5.
    To toggle back to Flash version:
    1) Go to VisualRF -> Setup tab
    2) Toggle Enable HTML5-based UI = no
    3) Save
    4) Give it a minute
    5) Navigate to building with the region to duplicate
    6) Either duplicate floor (with copy regions checked) or click into the floor and copy the region to floors above only.  If you need to copy regions to a floor below, you'll have to play with floor plan numbers to get it so that all floors are above the floor that has the region to copy.
    7) Repeat steps 1-3 (toggling yes) to revert back to HTML5
