Corporate DNS Domain
  • 1.  Corporate DNS Domain
    Posted Apr 24, 2014 11:20 PM
    Dear all
    I would like to configure Corporate DNS Domain with remote ap
    In AP system profile there is option Corporate DNS Domain . so I put the DNS domain (google.com)
    I follow under step.
    Defining Corporate DNS Servers
    Clients send DNS requests to the corporate DNS server address that it learned from DHCP. If configured for split
    tunneling, corporate domains and traffic destined for corporate use the corporate DNS server. For non-corporate
    domains and local traffic, other DNS servers can be used.
    In the WebUI
    1. Navigate to Configuration > Wireless > AP Configuration page.
    2. Select either the AP Group or AP Specific tab. Click Edit for the AP group or AP name.
    3. Under Profiles, select AP, then AP system profile.
    4. Under Profile Details:
    a. Enter the corporate DNS servers.
    b. Click Add.
    The DNS name appears in Corporate DNS Domain list. You can add multiple names the same way.
    5. Click Apply.
    In the CLI
    ap system-profile <profile>
    dns-domain <domain name>
    where I put the DNS ip for split user ? ???????
    It doest DNS IP address for (google.com)
  • 2.  RE: Corporate DNS Domain
    Posted Apr 24, 2014 11:57 PM
    Your corporate DNS server address will come from DHCP.
  • 3.  RE: Corporate DNS Domain
    Posted Apr 25, 2014 12:49 AM
    Dear Tim.
    User IP and DNS Ip come controller DHCP.
    subnet 10.56.201.0 netmask 255.255.255.0 {
    default-lease-time 28800;
    max-lease-time 28800;
    option vendor-class-identifier "ArubaAP";
    option vendor-encapsulated-options "172.16.0.254";
    option domain-name-servers 10.22.1.6
    option routers 10.56.201.1;
    range 10.56.201.2 10.56.201.254;
    authoritative;
    Over DNS IP(10.22.1.6)  is our campany local dhcp server ip.
    But I want to use deffernt DNS IP for branch office user.
    If I put the Corporate NDS Domain like under.
    When user find google.com. dns quarry to 10.22.1..6 .
    Can it change dns ip(local isp dns) when user find google.com ?
    AP system profile "vbn_test"
    Parameter Value
    LMS IP N/A
    LMS IPv6 N/A
    Backup LMS IP N/A
    Backup LMS IPv6 N/A
    LMS Preemption Disabled
    LMS Hold-down Period 600 sec
    Number of IPSEC retries 360
    LED operating mode (11n APs only) normal
    RF Band g
    Double Encrypt Disabled
    Root AP Disabled
    Native VLAN ID 1
    SAP MTU N/A
    Bootstrap threshold 8
    Request Retry Interval 10 sec
    Maximum Request Retries 10
    Dump Server N/A
    Telnet Disabled
    SNMP sysContact N/A
    AeroScout RTLS Server N/A
    RF Band for AM mode scanning all
    RTLS Server configuration N/A
    Remote-AP DHCP Server VLAN N/A
    Remote-AP DHCP Server Id 192.168.11.1
    Remote-AP DHCP Default Router 192.168.11.1
    Remote-AP DHCP DNS Server N/A
    Remote-AP DHCP Pool Start 192.168.11.2
    Remote-AP DHCP Pool End 192.168.11.254
    Remote-AP DHCP Pool Netmask 255.255.255.0
    Remote-AP DHCP Lease Time 0 days
    Remote-AP uplink total bandwidth 0 kbps
    Remote-AP bw reservation 1 N/A
    Remote-AP bw reservation 2 N/A
    Remote-AP bw reservation 3 N/A
    Heartbeat DSCP 0
    Session ACL ap-uplink-acl
    Corporate DNS Domain google.com
    Maintenance Mode Disabled
    Remote-AP Local Network Access Disabled
  • 4.  RE: Corporate DNS Domain
    Posted Apr 25, 2014 06:59 AM
    When you set the "Corporate DNS Domain" parameter, everything that has "google.com" will allow DHCP requests to go to the corporate DNS server at 10.22.1.6.  All other DNS resolution will be pointed at the DNS server obtained by the RAP where it is plugged in.  For example, if you plugged in that RAP at your home that has your ISP's DNS server, all non "google.com" DNS traffic will be resolved by your ISP's DNS server.  The key is to plug the RAP in on a connection where it will obtain a DNS server from the local site.
    Your must have your wireless traffic on a split tunneled Virtual AP for this to happen.
