Correct PoE injector for 205
  • 1.  Correct PoE injector for 205
    Posted Jul 18, 2017 02:24 AM
    What is the correct Watts, Volts and Amp injector needed for the 205?
    I have a 55V 0.6A that our supplier gave us with the 205, it works but the 205 unit gets extremly hot.
  • 2.  RE: Correct PoE injector for 205
    MVP EXPERT
    Posted Jul 18, 2017 05:03 AM
    Hey, according to the AP205 datasheet Aruba recommends the following POE injector.
    JW627A : PD-3501G-AC 15.4W 802.3af PoE 10/100/1000Base-T Ethernet Midspan Injector
    Which one are you using?
  • 3.  RE: Correct PoE injector for 205
    Posted Jul 18, 2017 09:02 AM
    If you are using a POE injector, it MUST be certified and rated for 802.3af/at. If you are using a power supply (power conenctor, not in-line with ethernet) then it should not be used on that AP.
