Thanks...I have seen this one....didnt help much with controller 6000
That's because the 6000 series is very old. I would look at the quickstart guide and user for 5.x here: https://support.arubanetworks.com/Documentation/tabid/77/DMXModule/512/EntryId/3795/Default.aspx
Colin,
Thank you for the great post. Is there a similar setup guide for Aruba Clearpass?
There is no video, but the ClearPass Deployment Guide here: https://support.arubanetworks.com/Documentation/tabid/77/DMXModule/512/Command/Core_Download/Default.aspx?EntryId=19058 is the closest thing to it.
You can also explore the technotes folder here: https://support.arubanetworks.com/Documentation/tabid/77/DMXModule/512/EntryId/7961/Default.aspx
