Could the noise affect the RSSI ?
  • 1.  Could the noise affect the RSSI ?
    Posted Dec 24, 2015 12:27 AM
    Hi Guys,
    Could the noise affect the RSSI?
    Even the noise is very high, but I think it may not be able to affect the RSSI, right?
  • 2.  RE: Could the noise affect the RSSI ?
    Posted Dec 24, 2015 12:30 AM
    That is correct. But it'll affect the SNR.
    Rajaguru Vincent
  • 3.  RE: Could the noise affect the RSSI ?
    Posted Dec 24, 2015 12:39 AM
    But what would happen if  STA get a very high RSSI but a very low SNR?
    Because in RF Optimization profile, the AP only measures the RSSI.
    Does the AP send a deauth to the STA?
  • 4.  RE: Could the noise affect the RSSI ?
    Posted Dec 24, 2015 01:15 AM
    If RSSI is high, then SNR should also be high.
    For example,
    Noise floor =  -90 dBm
    RSSI =  -35 dBm (high RSSI)
    SNR = 55 (high SNR)
    If RSSI is low,
    RSSI = -80 dBm (low RSSI)
    SNR = 10 (low SNR)
    In RF optimization profile, the RSSI threshold value can be 1-255. Here RSSI is not measured in dBm, but a relative measure of signal strength on a scale of 0-255.
    Rajaguru Vincent
  • 5.  RE: Could the noise affect the RSSI ?
    Posted Dec 24, 2015 01:25 AM
    What if we increace the noise only, would the RSSI be affected by the high noise?
    For example:
    SNR = 55 (high SNR)
    Some how, the noise floor increaced, maybe some one turned on a oven, then
    Noise floor =  -50 dBm
    Would the RSSI still be -35 dBM?
    Even if the RSSI still be -35 dBM, would the controller send a deauth to the STA because of the low SNR?
  • 6.  RE: Could the noise affect the RSSI ?
    Posted Dec 24, 2015 01:27 AM
    It's a ratio..
    Sent from Nine
  • 7.  RE: Could the noise affect the RSSI ?
    Posted Dec 24, 2015 01:35 AM
    Noise floor usually won't go that high in real world.
    RF optimization profile will look at only the RSSI. Noise or the SNR change will not trigger a deauth. If RSSI goes low, it will trigger a deauth.
    Rajaguru Vincent
  • 8.  RE: Could the noise affect the RSSI ?
    Posted Dec 24, 2015 01:51 AM
    I think this a design flaw, Controller should measure bothe the SNR and RSSI.
  • 9.  RE: Could the noise affect the RSSI ?
    Posted Dec 24, 2015 02:08 AM
    ClientMatch does that. RF optimization profile is an old one.
    Rajaguru Vincent
  • 10.  RE: Could the noise affect the RSSI ?
    Posted Dec 24, 2015 02:11 AM
    Thanks.
  • 11.  RE: Could the noise affect the RSSI ?
    Posted Dec 24, 2015 01:37 AM
    Yes , it's a ratio.
    We shouldn't say RSSI = -35 dBM, but RSSI can be convert to Power Value.
    Like RSSI 50* K = -35 dBM , every vendor have a different K value.
