Coverage in elevator shaft
This thread has been viewed 22 times
  • 1.  Coverage in elevator shaft
    Posted Aug 21, 2014 02:02 AM
    HI All,
    I've had a strange request from a client to provide WiFi inside the elevators in high rise building.
    In principle it sounds doable, get a cable in and mount the AP in the ceiling. The more i think about it the more i think - bad idea.
    Has anybody ever done this before? What was your experience? My concern is that this would play havoc with ARM / Roaming each time the AP passes a floor.
    Scott
  • 2.  RE: Coverage in elevator shaft
    Posted Aug 21, 2014 04:00 AM
    That is a very interesting request indeed.  Not something I've done before.
    If the lift is contained in a solid shaft and not one of those glas ones, I don't think you need to worry too much about ARM.  Perhaps just set a static channel and the lowest power you can.
    Not sure where you would place that AP on an Airwave VisualRF plan though. ;-)
  • 3.  RE: Coverage in elevator shaft
    Posted Aug 21, 2014 05:46 AM
    Elevator coverage is always a subject that comes up during design, but rarely is implemented due to extensive costs. Wiring/bridge to the elevators and APs in every elevator would require a good salesperson to seem economically sound for that 30-second ride.  However, if the application is important enough, the price is never too high. Although this should not be the location you place your most expensive APs.
    As Michael is saying, I would not worry about ARM; with the AP limited to the lowest power, the attenuation through the elevator casing and the elevator shaft should well prevent any interference with the other APs on the passing floors. Naturally, the elevator lobby would be affected when the doors open, so keep that in mind when you design your network.
    I would however not use static channels for the elevator-APs, as they should be able to move to a different channel if they themselves are affected by noise or interference. Potentially this could cause problems when multiple elevators run inside a single shaft. I would recommend you monitor the channel use and if the APs frequently are changing channels, you could try the static approach. Make sure you analyze the spectrum while the elevators are running/standing at the same floor.
    The typical problem is however how to wire the AP in the elevator. With the maximum allowed length of a Cat 6 cable at 100 meters, you might be short in your “high rise building”. The most discussed option is to deploy a directional antenna (high gain dish/sector etc.) at the floor or ceiling of the elevator shaft or even a similar wireless bridge to the elevator. There is also a few interesting posts on running DSL to the elevators in high buildings on the Whirlpool Forums; http://bit.ly/1kXipuU.
    Either way, let us know how you proceed. Good luck! :)
    Jan Vidar
  • 4.  RE: Coverage in elevator shaft
    Posted Feb 01, 2021 09:53 AM
    Hi, I have used this design with wireless mesh successfully for hotels.
    2-node mesh: for about 20 floors and below (Sheraton Manila @ 14 floors)
    3-node mesh: for 21 floors and taller (Shangri-la Makati @ 28 floors) - with a different vendor then
    Using this design guest can successfully roam from guest room to corridor to elevator to lobby pretty much seamlessly as long as you have the same SSID and use the same vlan across the property.
    Tee Chong Lee
  • 5.  RE: Coverage in elevator shaft
    Posted Aug 21, 2014 06:38 AM
    Yes, ARM becomes an issue when the doors of the elevator open and the signal bleeds out. Many deployments will choose a single channel for the elevator which is not available for use on the floors.
  • 6.  RE: Coverage in elevator shaft
    Posted Aug 21, 2014 02:15 PM
    You could use "leaky coax" and run it down the entire length of the elevator.  PLace a 50 ohm dummy load on one end, and a AP-175 on the other.  But, this would be expensive because the coax will have to be a large diameter for 2.4 and 5.8 GHz.  This is similar to whay they do in tunnels.
    Matt
  • 7.  RE: Coverage in elevator shaft
    Posted Aug 22, 2014 10:58 PM
    If you do decide to go with an in-car AP, be aware that it's pretty tough to find cat6 cables that are certified for use in an elevator.  Due to the constant flex on the cables as the car goes up and down, plus the fact that it's considered a life/safety environment, most cat6 cables can't be installed - especially solid conductor.  As part of installing IP surveillance cameras a few years back, the only good option that I found was Datwyler 191032, which comes in a mostly cat6 option.
    The "mostly" part is that in order to meet the constantly flex requirements, the cables are smaller than normal - 26 gauge.  This means that they'll only perform cat6 at up to 65m, rather than the normal 100m.  Depending on your cable paths, you may want to consider installing a small switch in your elevator machine room to minimize the cable run length.  In addition, you'll have to be careful about how much power loss is incurred, and what this does to your PoE budget.
    On the plus side, the cable is a single flat jack about 1 inch wide containing 4 cat6 cords, so a single pull gets you plenty of spares for adding cameras or dealing with a broken cable without bringing the costly elevator service tech in.
  • 8.  RE: Coverage in elevator shaft
    Posted Aug 22, 2014 11:04 PM
    Have you considered doing a mesh deployment? Then you would only need power in the car. No data. Obviously depends on how many floors the building is.
  • 9.  RE: Coverage in elevator shaft
    Posted Aug 26, 2014 07:11 PM
    Hi All,
    Thankyou for the great tips and considerations that i didn't think about. This is still in the "can we do it" stage with the customer so no firm plans as of yet.
    My feeling is the cost will be hard to justify for the benefit.
    Scott
  • 10.  RE: Coverage in elevator shaft
    Posted Sep 06, 2018 10:16 AM
    I face a similar request: a six story hotel would like to have WLAN coverage in the elevator shaft. Would deploying an AP with an external antenna, mounted at the roof of the elevator shaft give that coverage?
