Is there any documentation aside from the links below that details the API entities available for use?
http://d1x3hnhct7p62q.cloudfront.net/SupportSite/ProductionFiles/d339a054-0e3e-4bab-b6c4-4e573933e3de/Avenda_eTIPSapi.pdf?Expires=1397195639&Signature=g3hzN5wNswNjahHnRFJ7P~I~89qSr~maVsKYRjd9CGKBJLuTKQNWy67RdMZI10PEycC-3xSljYoc4YbaKjW~wufSUpOT8yEmreqoRR3H1YMuHtZjEPd3yVKeNZFRTjRy9ZKG7jWCfd7eWeWBl-bpTpvL6JEBHCfpt2A9nYorFkTdSZEUUasCcXtLTteLn-VGZ76vKs6cb8yU3cNTvkhY~l46zWXrkuV~THmXMNwyjW7vyxQrrzO7wIgmVZ2Ytxd5pyOGeXi5AS8yjIdbRYeD0bdKYok99MomiK5QJYeEVoaInpCBwKJqgNsao8JWShgcuzNUIkK7Ef50F6gx1Dan0Q__&Key-Pair-Id=APKAJCOCR7KIA7QV5SEQ
http://community.arubanetworks.com/aruba/attachments/aruba/aaa-nac-guest-access-byod/5817/1/ClearPassProfileTechNote.pdf
http://support.arubanetworks.com/Documentation/tabid/77/DMXModule/512/Command/Core_Download/Default.aspx?EntryId=9155
The Doc are all on the server also
Go to the following page and the WSDL is there and if you click the help on the top there is more detailed information.
Yep, that information is present in the attached links and also the User Guides.
Apart from aquisition, is there any reason why there are at least 3 different types of API?
