CP Guest - check blacklist for self-registration
  • 1.  CP Guest - check blacklist for self-registration
    Posted Feb 15, 2013 10:38 AM
    Hello!
    Got a self-registration portal with password sendt as SMS to the supplied cellphonenumber.
    Now - to avoid internal users using the guest network for their various devices we have a long list of known cellphonenumbers that should be check as a blacklist which should stop registration.
    I know you can check for validPhoneNumber and edit the array there, but thats sorta difficult to maintain. The list is already in a php serverpage so ideally it could make a check against this before allowing the registration to complete.
    Any thoughts on how to accomplish this?
  • 2.  RE: CP Guest - check blacklist for self-registration
    Posted Feb 15, 2013 02:34 PM
    I don't think this is currently supported with the validation architecture today.  You could file an RFE for this type of functionality if you had a bit more detail (by "PHP serverpage" I assume you mean some kind of HTTP based lookup would be used to determine if the phone number is on the blacklist or not?)
  • 3.  RE: CP Guest - check blacklist for self-registration
    Posted Feb 15, 2013 03:48 PM
    >>>>by "PHP serverpage" I assume you mean some kind of HTTP based lookup would be used to determine if the phone number is on the blacklist or not?) Exactly right. But without that feature - would it be possible to have several thousand numbers in the validation array for the field?
  • 4.  RE: CP Guest - check blacklist for self-registration
    Posted Feb 15, 2013 05:56 PM
    In principle, it is possible.  In practice, the management of that could be somewhat of a challenge.
