Is it possible to retrieve in my Syslog server the information I can see on Access Tracker - Request Details - Show logs (RadiusServer.Radius) ?
Dimitri
You create a filter and chose what information that you want CPPM to send. In addition you can also do a custom SQL query. You should work with you local SE or TAC to create the filter.
