CP Guest Redirection not happening automatically
  • 1.  CP Guest Redirection not happening automatically
    Posted Feb 06, 2018 12:56 PM
    Dears,
    1)I have created weblogin page in CP Guest. (Registerpage: https://192.168.1.3/guest/arubalogin.php)
    Conf below11
    22
    33
    44
    55
    66
    2)then I created a service in CP with simple allow access policy. with authentication set to guest user repositary.
    1122
    Then Created an SSID with following config in wizard.
    SSID Name: guestP-T
    Forwarding Mode: tunnel
    Radio Type:All
    Broadcast SSID: Yes
    Vlan: 10 (192.168.1.0/24)
    Internal/Guest: Guest
    Auth... and Encr...:  Captive Portal with Auth. via credentials (Username& Password) provided by user
    Captive portal: Enabled
    Authentication server: (External)192.168.1.3
    Role Assi...: Pre-auth Role: guestP-T-guest-logon
                         Authenticated Role: Guest
    Finish.
    4)Under Configuration- Authentication- L3 Authentication-Captive Portal Authentication-guestP-T-cp_prof
    edited login page to: https://192.168.1.3/guest/arubalogin.php
    apply and save conf.
    Now when i connect to this SSID and try to browse to 1.1.2.3 (Any IP)
    I am not getting redirected to login page.
    But when i enter "https://192.168.1.3/guest/arubalogin.php" Manually, things run fine.
    Please help to figureout the issue.
  • 2.  RE: CP Guest Redirection not happening automatically
    Posted Feb 06, 2018 01:06 PM
    1) Why are you using an IP address instead of an FQDN? ClearPass should only be accessed via FQDN
    2) Does your controller have an IP address in the client subnet?
