HI all,
I am using captive portal with CPPM, now I want to limit the access time of the guest.
Means after 1hr of authentication user should get disconnect.
plz give me some point.
Thanks for your prompt reply,
Sorry I'm not able to find out what all are you said.
Please upload some screenshot.
Any doc will be very helpful.
Rana,
For answers to this and other questions, please take a look at the clearpass guest user guide here: http://support.arubanetworks.com/Documentation/tabid/77/DMXModule/512/Command/Core_Download/Default.aspx?EntryId=14795
Sorry for digging the post again,
I have read the Clearpass guest user guide.
Now I have one more question, If I use external captive portal then how can I limit the Guest user session time and after that the account should expire.
