  • 1.  CP-REDIRECT
    Posted Jun 09, 2014 05:24 PM
    Hello to all,
    We have the following scenario ... We have a local controller in Layer 2 which has the default gateway pointing to the master controller.
    Local Controller:
    vlan 351
    IP: No ip address
    Master controller:
    vlan 351
    IP: 172.27.0.1 (vrrp)
    The client of the local controller connects to the ssid that distributes vlan 351, it is configured DHCP help address, the client gets the IP address but can not open the captive portal.
    Have tried the cp-redirect command pointing to the vip and also specifically to the ip of master and did not work. Anyone have any tips?
    Thx
  • 2.  RE: CP-REDIRECT
    Posted Jun 09, 2014 06:54 PM
    Try to put an ip on the local controller for vlan 351.  The state of the user and role is handled by the controller that the user is connected to.  It needs an ip address on that vlan to be able to bring up the captive portal.
  • 3.  RE: CP-REDIRECT
    Posted Jun 10, 2014 05:17 PM
    Thanks for the reply, putting IP worked perfectly.
    Regards
