CPG- Error 500
  • 1.  CPG- Error 500
    Posted Apr 12, 2018 08:51 AM
    Hi Everyone, just started to expirience this issue with our ClearPass Guest, we use CPPM as a Radius dot1x to gain access to our corp network, we setup a custom Guest Portal that allows the HelpDesk Team to create new devices, basically add MAC address to a whitelist for new computer being provision, I was checking the logs from the Clear Pass Guest Administration/Support/Application_log and found out that only is happening with the HelpDesk Group, we use the "Device Registration" profile for HelpDesk and "Super Administrator" role for domain Admins group.Gues Manager.PNG
    In the device Registration settings we use a custom setting for the Guest Manager Operator privileges that allows only to see specific fields on the Guest Creation Web Page, looks like could be a Postgress Issue?, just want to touch base and see if someone have a similar issue. Only happens if you clic the "Manage Devices" that I believe is pointing to "guest/mac_list.php" list. When I login as a Super Administrator this does not happen.
    P.S. This error started like two weeks ago, we hadn't applied any patches to ClearPass, and we do not use amigopod. ClearPass Version 6.6.9.102777
  • 2.  RE: CPG- Error 500
    Posted Apr 18, 2018 05:32 PM
    I have come across a similar issue and the solution was to navigate to the specific Operater Login Profile and remove the Roles assigned.
    Administration > Operator Logins > Profiles
    Select and Edit the Profile
    Scroll down to User Roles and uncheck the check boxes for Roles for the operator profiles(uncheck Contractor, Guest, Employee)
    And save the profile.
    Prat
  • 3.  RE: CPG- Error 500
    Posted Apr 19, 2018 08:40 AM
    Patch 10 fixed the issue with the Guest Portal, I just installed the new version and it's working fine.
