CPPM + 2930F - Downloadable User Roles Failing
This thread has been viewed 34 times
  • 1.  CPPM + 2930F - Downloadable User Roles Failing
    Posted Aug 03, 2019 08:49 PM
    I'm running a 2930F w/ 16.08 firmware and I'm attempting to get DUR working with ClearPass. I've followed the wired guide pretty closely but I'm getting some errors.
    For the purposes of testing, I created a simple allow all and DHCP only policy w/ MAC auth.
    Allow All:
    class ipv4 IP-ANY-ANY match ip any any
    exit
    policy user "DUR-Data-Allow-All"
    10 class ipv4 IP-ANY-ANY action permit
    exit
    aaa authorization user-role name "DUR-Data-Allow-All"
    policy "DUR-Data-Allow-All"
    vlan-name "Lab Network"
    exit
    DHCP Only:
    class ipv4 DHCP match udp any any eq 67
    exit
    policy user "DUR-DHCP-Only"
    10 class ipv4 DHCP action permit
    20 class ipv4 IP-ANY-ANY action deny
    exit
    aaa authorization user-role name "DUR-DHCP-Only"
    policy "DUR-DHCP-Only"
    exit
    When I enable debugging on the switch (user-profile-mib, cppm, event), I can see that the communication between CPPM and Switch appears to be working but the switch seems to have an issue with the above roles.
    Aruba-Lab-SW1#
    0002:05:39:29.43 UMIB m8021xCtrl:removing dca client f0def1-7b4652 for port 8.
    I 01/02/90 21:39:29 00077 ports: port 8 is now off-line
    I 01/02/90 21:39:29 00002 vlan: Default virtual LAN disabled (1 times in 60
                seconds)
    I 01/02/90 21:39:33 00435 ports: port 8 is Blocked by AAA
    0002:05:39:33.75 UMIB tRadiusR:Received cppm downloadable user role vsa for
       client with request-id 28 and assigned user role is :
       Aruba_DUR_Data_Allow_All-3016-5
    0002:05:39:33.75 UMIB mdcaCtrl:New node is created for the downloadable user
       role Aruba_DUR_Data_Allow_All-3016-5
    0002:05:39:33.75 UMIB mdcaCtrl:DUR Client with request-id 28 is added to waiting
       queue for downloadable user role Aruba_DUR_Data_Allow_All-3016-5 in INITIAL
       state
    0002:05:39:33.75 UMIB mdcaCtrl:Posting event to cppm task to  download the
       userRole Aruba_DUR_Data_Allow_All-3016-5
    0002:05:39:36.49 UMIB mcppmTask:Download of user role
       Aruba_DUR_Data_Allow_All-3016-5 failed with error code 35 : cppm server url
       https://172.16.10.41/async_netd/arubacppmapi/downloadableconfig?role=Aruba_DU
    0002:05:39:36.49 UMIB mcppmTask:Download of userRole
       Aruba_DUR_Data_Allow_All-3016-5 is failed
    0002:05:39:36.50 UMIB mdcaCtrl: Sending message to authentication task for
    0002:05:39:36.50 UMIB mdcaCtrl:Removing DUR Client with request-id 28 for
       downloadable user role Aruba_DUR_Data_Allow_All-3016-5 from waiting queue as
       role download failed
    0002:05:39:36.50 UMIB mWebAuth:macAuth client F0DEF17B4652 on port 8 assigned to
       initial role as downloading failed for user role Aruba_DUR_Data_Al....
    0002:05:39:36.50 UMIB mWebAuth:added new dca client f0def1-7b4652 for new client
       port 8.
    0002:05:39:36.50 UMIB mWebAuth:Client Mac F0DEF1-7B4652, accessMode MacAuth
    W 01/02/90 21:39:36 05620 dca: macAuth client F0DEF17B4652 on port 8 assigned to
    W 01/02/90 21:39:36 05204 dca: Failed to apply user role
                Aruba_DUR_Data_Allow_All-3016-5_7Z4q to macAuth client F0DEF17B4652
                on port 8: user role is invalid.
    I 01/02/90 21:39:36 00435 ports: port 8 is Blocked by STP
    0002:05:39:38.71 UMIB m8021xCtrl:removing dca client f0def1-7b4652 for port 8.
    0002:05:39:38.71 UMIB m8021xCtrl:added new dca client f0def1-7b4652 for new
       client port 8.
    0002:05:39:38.71 UMIB m8021xCtrl:Client Mac F0DEF1-7B4652, accessMode 8021x
    I 01/02/90 21:39:39 00076 ports: port 8 is now on-line
    I 01/02/90 21:39:39 00001 vlan: Default virtual LAN enabled (1 times in 60
                seconds)
    I 01/02/90 21:40:18 00428 802.1x: 1 auth-failures for the last 60 sec.
    If I'm reading the above correctly, it looks like the switch is failing w/ error code 35? cppm server url?
    Does anyone have any additional insight on this?
  • 2.  RE: CPPM + 2930F - Downloadable User Roles Failing
    Posted Aug 03, 2019 09:12 PM
    I found some errors in the above policies but I did get the revised roles to be accepted in the switch's configuration when I entered them manually. DUR is still not working.
    The revised roles are as follows:
    Allow all:
    match ip any any
    exit
    policy user Allow-All-ACL
    exit
    aaa authorization user-role name DUR-Data-Allow-All
    policy Allow-All-ACL
    exit
    DHCP Only:
    match ip any any
    class ipv4 DHCP
    exit
    policy user DHCP-Only-ACL
    exit
    aaa authorization user-role name DUR-DHCP-Only
    policy DHCP-Only-ACL
    exit
  • 3.  RE: CPPM + 2930F - Downloadable User Roles Failing
    Posted Aug 04, 2019 04:00 PM
    Fixed it!
    Switch clock was wrong. Reset it w/ NTP and the DURs started working!
