last person joined: 9 hours ago
CPPM 6.11.0 TACACS not in access tracker
This thread has been viewed 27 times
  • 1.  CPPM 6.11.0 TACACS not in access tracker
    Posted Nov 01, 2022 11:48 AM
    I have installed a new ClearPass 6.11.0 server and restored a configuration backup of a 6.10.7 installation.
    Now my TACACS authentications are not appearing in the access tracker.
    I can see the counters in the services increasing.
    All Radius requests are normal in the access tracker.
    I have checked on my Fortigate and monitored traffic and I can see the Tacacs request being answered by CPPM.
    The authentication is also working as expected.
    Best regards,
    Rob Hassing
  • 2.  RE: CPPM 6.11.0 TACACS not in access tracker
    Posted Nov 01, 2022 11:53 AM
    Hi Rob
    I had the same issue in 6.10 after upgrading from 6.9.
    The issue was solved by TAC, so I should contact TAC if I got this behavior. I don't think you can do anything.
    In the cluster we had the issue on two out of three servers. One was working normally with the TACACS requests showing up in the Access Tracker
    Best Regards
    Jonas Hammarbäck
    ACCX #1335, ACMP, ACDP, ACNSP, ACEP, ACSA
    Aranya AB
  • 3.  RE: CPPM 6.11.0 TACACS not in access tracker
    Posted Nov 02, 2022 03:40 AM
    In my case after upgrade to 6.10.7 TACACS server on publisher just stop responding. Port 49 is closed and all TACACS requests are served from subscriber. Working with TAC on this problem, but no resolution on horizon yet.
    Best, Gorazd
    Gorazd Kikelj
  • 4.  RE: CPPM 6.11.0 TACACS not in access tracker
    Posted Nov 02, 2022 09:40 AM
    Curious what the use-cases are for upgrading/running 6.11.0?  Typically running a .0 release is not recommended.  I always like waiting until at least the first patch is released.
  • 5.  RE: CPPM 6.11.0 TACACS not in access tracker
    Posted Nov 02, 2022 10:49 AM
    This is not a real production environment and I would like to test the upgrade procedure.
  • 6.  RE: CPPM 6.11.0 TACACS not in access tracker
    Posted Nov 02, 2022 01:16 PM
    It's not really upgrade. It is migration due to change in the underlaying linux distribution to RedHat enterprise. So you need to install new Clearpass server and import databases, certificates and other bits and pieces.
    Best, Gorazd
    Gorazd Kikelj
  • 7.  RE: CPPM 6.11.0 TACACS not in access tracker
    Posted Nov 03, 2022 05:25 AM
    According to the documentation it was possible to restore a backup of the 6.10.7 installation.
  • 8.  RE: CPPM 6.11.0 TACACS not in access tracker
    Posted Nov 03, 2022 08:55 AM
    Herman did a great youtube video on this topic.
    Video link
    Best, Gorazd
    Gorazd Kikelj
