CPPM 6.2 - Creating Enforcement Profiles
  • 1.  CPPM 6.2 - Creating Enforcement Profiles
    Posted Oct 22, 2013 03:30 PM
    I'm trying to create enforcement profiles to return radius attributes to a Cisco ASA to define the Class [25] attribute, which we use for Access Profiles on the ASA.
    When I create a generic radius enforcement (which is supposed to let me return any enabled radius dictionary attributes) I have no available attributes.
    I had previously created a similar profile to enable Radius auth to our APC ups devices which returned a radius attribute to let certain users (based on AD membership) have admin privilege. This profile seems to have been stripped of all configuration and returns an error in CPPM when I try to edit it.
    The radius dictionaries I need are enabled.
    Am I missing something obvious here or should I just open a TAC case?
    Thank in advance
  • 2.  RE: CPPM 6.2 - Creating Enforcement Profiles
    Posted Oct 22, 2013 04:17 PM
    Thank in advance
    EDIT:  If your dictionaries are enabled, you should open a TAC case, being that no attributes are showing up.  You can also try disabling then enabling attributes.
  • 3.  RE: CPPM 6.2 - Creating Enforcement Profiles
    Posted Oct 22, 2013 04:29 PM
    Thanks for the quick response.
    That is what I was doing, but when I click on ANY, enabled or disabled, radius dictionary I get this.
  • 4.  RE: CPPM 6.2 - Creating Enforcement Profiles
    Posted Oct 22, 2013 04:31 PM
    - What browser are you using?
    - It worked before, right?
  • 5.  RE: CPPM 6.2 - Creating Enforcement Profiles
    Posted Oct 22, 2013 04:32 PM
    Chrome.
    Yes, I have been through this with the APC units we setup.
    I will try IE. If thats the answer I will feel pretty bone headed.
  • 6.  RE: CPPM 6.2 - Creating Enforcement Profiles
    Posted Oct 22, 2013 04:33 PM
    I don't think that is the answer. We use chrome without issue, so it should not be a problem. You should open a TAC case....
  • 7.  RE: CPPM 6.2 - Creating Enforcement Profiles
    Posted Oct 22, 2013 04:35 PM
    Just tried IE and there is no change.
    Thanks for the input, I will open a TAC case.
  • 8.  RE: CPPM 6.2 - Creating Enforcement Profiles
    Posted Oct 22, 2013 04:46 PM
    What version of CPPM are you using?
  • 9.  RE: CPPM 6.2 - Creating Enforcement Profiles
    Posted Oct 22, 2013 04:52 PM
    ClearPass Policy Manager 6.2.1.55992
    We upgraded from 6.0.something about 6 weeks ago.
  • 10.  RE: CPPM 6.2 - Creating Enforcement Profiles
    Posted Oct 22, 2013 04:55 PM
    There was a bug in one of the older versions but since you are at the latest, colin is right you should open a tac case
  • 11.  RE: CPPM 6.2 - Creating Enforcement Profiles
    Posted Oct 22, 2013 04:34 PM
    Make sure you use capability mode in IE
