CPPM 6.3 Guest Sponsorship - Radius Failure
  • 1.  CPPM 6.3 Guest Sponsorship - Radius Failure
    Posted Jun 22, 2014 09:27 PM
    ClearPass Cumulative Patch 3 for 6.3.0, 6.3.1, 6.3.2*+
    Policy Manager software version : 6.3.3.63748
    Policy Manager model number     : CP-VA-5K
    AP - Aerohive
    CWP using https with valid 3rd party certificates
    Here is what is happening
    guest connects to guest ssid
    opens browser and is redirected to ClearPass guest for self registration
    Guest picks a sponsor and fills in the required info
    sponsor gets email and clicks to enable
    guest login button gets enabled
    receipt sent to sponsor
    guest clicks on the login button and authentication fails
    debug shows that the AP gets a weird password from the submit form
    post input: username=chuck%40n.com&
    password=3433323833333636
    password should be
    43283366
    as you can see the submit form is adding a 3 between every number
    3433323833333636
    If the guest uses the regular login form and enters the username and password that was created through the sponsor process then authentication is successful.
    I am not sure where to look to stop the submit button from adding the extra 3s
    Cheers
  • 2.  RE: CPPM 6.3 Guest Sponsorship - Radius Failure
    Posted Jun 23, 2014 12:09 AM
    When you are clicking login its the NAS device is the one submiting the auth request to CPPM. You can do a packet capture to comfirm but most likely the issue is coming from the NAS doing a radius auth to CPPM. You will need to double check your settings in the NAS.
    In the standard AAA framework, network access is provided to a user according to the following process:
     *The user connects to the network by associating with a local access point [1].
     *A landing page is displayed to the user [2] which allows them to log in to the NAS [3][4] using the login name and password of their guest account.
     *The NAS authenticates the user with the RADIUS protocol [5].
     *ClearPass Policy Manager determines whether the user is authorized, and, if so, returns vendor-specific attributes [6] that are used to configure the NAS based on the user’s role and other policies [7].
     *If the user’s access is granted, the NAS permits the guest access to the network based on the settings provided by the ClearPass Policy Manager server.
     *The NAS reports details about the user’s session to the ClearPass Policy Manager server using RADIUS accounting messages [8].
     *After the user’s session times out [9], the NAS will return the user to an unauthorized state and finalize the details of the user’s session with an accounting update [10].
  • 3.  RE: CPPM 6.3 Guest Sponsorship - Radius Failure
    Posted Jun 23, 2014 12:35 AM
    Thanks tarnold
    The normal web login page works as expected - username and password entered and submitted are passed to NAS unmolested.
    It is the sponsor receipt page after the sponsor confirms the guest. The input that the NAS receives from clicking  the submit button arrives at the NAS with 3s inserted. and then the NAS submits what it gets to the radius server.
    the normal login form for guests with accounts already
    2014-06-20 13:16:54 debug   ah_capture: [cgic_basic]: post input: password=50657397&username=sam%40j.com&Submit2=Submit&url=xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
    2014-06-20 13:16:54 debug   ah_capture: [cgic_basic]: Calling PostFormInput
    2014-06-20 13:16:54 debug   ah_capture: [cgic_basic]: POST recognized
    2014-06-20 13:16:54 debug   ah_capture: [cgic_verbose]: Submit2=Submit
    2014-06-20 13:16:54 debug   ah_capture: [cgic_verbose]: username=sam@j.com
    2014-06-20 13:16:54 debug   ah_capture: [cgic_verbose]: password=5***
    2014-06-20 13:16:54 notice  ah_capture: authentication OK, username sam@j.com, service
    for the sponsor receipt page submit for guest self-registered with sponsor approval
    2014-06-20 13:15:29 debug   ah_capture: [cgic_basic]: post input: username=sam%40j.com&password=
    3530363537333937&Submit2=Submit&url=xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
    2014-06-20 13:15:29 debug   ah_capture: [cgic_basic]: Calling PostFormInput
    2014-06-20 13:15:29 debug   ah_capture: [cgic_basic]: POST recognized
    2014-06-20 13:15:29 debug   ah_capture: [cgic_verbose]: Submit2=Submit
    2014-06-20 13:15:29 debug   ah_capture: [cgic_verbose]: password=3***
    2014-06-20 13:15:29 debug   ah_capture: [cgic_verbose]: username=sam@j.com
    So if I understand your post, you are saying the NAS is somehow changing the post information?
    Because the debug looks like the NAS just passes along what it receives
    Cheers
  • 4.  RE: CPPM 6.3 Guest Sponsorship - Radius Failure
    Posted Jun 23, 2014 12:41 AM
    If you disable Sponsor approval are you getting the same result?
  • 5.  RE: CPPM 6.3 Guest Sponsorship - Radius Failure
    Posted Jun 23, 2014 12:57 AM
    With sponsor approval disabled
    account gets registered and email sent to sponsor and then screen refreshes with login button on receipt page
    click and auth fails
    same result
    2014-06-23 12:46:20 debug   ah_capture: [cgic_basic]: PostFormInput succeeded
    2014-06-23 12:46:20 debug   ah_capture: [cgic_basic]: post input: username=chucka%40d.com&password=3237303339393931&Submit2=Submit&url=xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
    2014-06-23 12:46:20 debug   ah_capture: [cgic_verbose]: password=3***
    2014-06-23 12:46:20 debug   ah_capture: [cgic_verbose]: username=chucka@d.com
  • 6.  RE: CPPM 6.3 Guest Sponsorship - Radius Failure
    Posted Jun 23, 2014 01:01 AM
    Did you happen to look through this How-To?
    Im not an expert on Aerohive, but I have not seen your issue on any other vendors. @Michael_Clarke did a great job on this and I would look though this guide and double check your settings.
    http://community.arubanetworks.com/t5/AAA-NAC-Guest-Access-BYOD/Tutorial-Aerohive-Integration-with-Clearpass-corp-and-guest-mhc/m-p/149134/highlight/true#M10724
  • 7.  RE: CPPM 6.3 Guest Sponsorship - Radius Failure
    Posted Jun 23, 2014 01:04 AM
    Sorry I take that back his how to was using web login not sponsor. I still think the issue is in your NAS.
  • 8.  RE: CPPM 6.3 Guest Sponsorship - Radius Failure
    Posted Jun 23, 2014 01:11 AM
    ok Thanks
    yes, I have reviewed the tutorial.
    This same sponsor setup worked with CPPM 6.2
    I'll keep plugging away until I find the cause.
    Cheers and thanks for your time
  • 9.  RE: CPPM 6.3 Guest Sponsorship - Radius Failure
    Posted Jun 23, 2014 01:14 AM
    Is this an upgrade or a new install?
  • 10.  RE: CPPM 6.3 Guest Sponsorship - Radius Failure
    Posted Jun 23, 2014 01:20 AM
    This is a new install.
    prior to buying Clearpass we had done testing with 6.2 since we had to integrate with Cisco and Aerohive wireless. I still have the 6.2 servers, but the temp licenses have expired. I will ask my local reseller if I can get a temp license to bring up the old servers. The major difference between then and now besides 6.2 and 6.3 is I now have valid 3rd party certificates installed.
    Cheers
  • 11.  RE: CPPM 6.3 Guest Sponsorship - Radius Failure
    Posted Jun 23, 2014 01:24 AM
    OK thank you. I wanted to make sure there were no issues on an upgrade.
    I would also open a TAC case just to double check on the CPPM side. I just looked and didn't see any known bugs on the CPPM side so it would be nice to have confirmation from TAC.
  • 12.  RE: CPPM 6.3 Guest Sponsorship - Radius Failure
    Posted Jun 23, 2014 10:58 PM
    Confirmed works in 6.2
    and doesn't work in 6.3
    on the test server I was using mschapv2 and UAM basic instead of chap and cleartext. Also on test server I did not have https enabled.
    I configured the ssid and CWP to point to the test server 6.2 and login was successful after sponsor confirmation.
    Used the same settings for the deployment 6.3 server and Auth fails after sponsor confirmation.
    It's a conundrum
    I managed to get this working.
    I had to adjust the NAS settings in the guest self-registration to use secure login with https - no password encryption
    on cwp page chap use secure login with https - no password encryption
    on the web login use secure login with https - no password encryption
    Anyone know what mschapv2 and UAM basic would fail?
    Cheers
