CPPM 6.7.7 patch suddenly not available
  • 1.  CPPM 6.7.7 patch suddenly not available
    Posted Dec 07, 2018 09:16 AM
    Good morning,
    I had planned to update my CPPM cluster from 6.7.3 to 6.7.7 this morning, only to find that it no longer shows up in the Software Updates section.
    I looked just yesterday and it was there, but when I click "Check Status Now" it does not find it.  (screenshot below) 2018_1207_CPPM-PatchNotAvailable01.JPG
    Anyone else having this issue?  Did the update get pulled?
    Thanks - Daniel
  • 2.  RE: CPPM 6.7.7 patch suddenly not available
    Posted Dec 07, 2018 09:45 AM
    Available in support site
  • 3.  RE: CPPM 6.7.7 patch suddenly not available
    Posted Dec 07, 2018 10:46 AM
    Fair point.  I overlooked that I could import updates into this section.  I was thinking it needed to be able to automatically find and download it to be able to use Cluster Update, but it seems it would work once I manually download and import the update.  I will give it another go this weekend hopefully.
    Still seems like it should be able to find the update automatically.  I've never seen this problem before...like I said it was there yesterday.  Anyone else see this behavior if you're not already on 6.7.7 as of today?
  • 4.  RE: CPPM 6.7.7 patch suddenly not available
    Posted Dec 07, 2018 12:36 PM
    I'm not running 6.7.7 and I see the same with the 6.7.7 replaced with "ClearPass 6.7.x Hotfix Patch for License Activations". I'm assuming Aruba wants you to apply this patch first before doing an update?.
  • 5.  RE: CPPM 6.7.7 patch suddenly not available
    Posted Dec 07, 2018 01:17 PM
    That's exactly what I thought, so I installed the hotfix but still got no other update options afterward even after checking many times. :-(
    By the way, the hotfix does is not disruptive (no reboot).
  • 6.  RE: CPPM 6.7.7 patch suddenly not available
    Posted Dec 10, 2018 09:57 AM
    This appears to be resolved...I see Patch 7 when I check for updates now.  Plus
