Is it currently possible to set a service not to log to the access tracker? I have 3 CPPM boxes that are behind a hardware load balancer. I have my load balancer setup to do a layer 7 healthcheck. The healthcheck happens very frequently. I would like to be able to set the healthcheck service I have setup in CPPM not to log to the access tracker.
I don't think so. Anything that hits a service will appear in access tracker. Anything that doesn't match a service will show up in the event viewer.
This sounds like a great feature request though!
I haven't tried this before but see if you could create a rule in the data filters for that specific token or pusture rule no to show up
Data filters would work, but they're only a "View". Each user would have to select this View in access tracker and each of your test authentication requests would still be counted in total authentications.
