  • 1.  CPPM - Adding network route error
    Posted Dec 04, 2014 06:50 AM
    Hi All,
    [appadmin@CPPM]# network ip add mgmt -d 10.0.0.0/8 -g 172.20.50.1
    ERROR - Failed add route for destination=10.0.0.0/8 via=172.20.50.1
    I'm getting the above error when attempting to add the route.
    The management interface gateway is 172.20.50.1.
    Any tips?
    Cheers
    James
  • 2.  RE: CPPM - Adding network route error
    Posted Dec 04, 2014 07:20 AM
    You have the right format , im wondering if maybe you have any spaces at the end ?
  • 3.  RE: CPPM - Adding network route error
    Posted Dec 04, 2014 07:25 AM
    No spaces on the end.. just double checked.
    If I change the netmask it's allowing me to add the rule. :s
    [appadmin@cppm]# network ip add mgmt -d 10.0.0.0/8 -g 172.20.50.1
    [appadmin@cppm]# network ip add mgmt -d 10.0.0.0/9 -g 172.20.50.1
    INFO - Added route for destination=10.0.0.0/9 via=172.20.50.1
    INFO - New ip rule created with the id = 12002
  • 4.  RE: CPPM - Adding network route error
    Posted Dec 04, 2014 07:27 AM
    I guess this'll have to do...
    [appadmin@cppm]# network ip add mgmt -d 10.128.0.0/9 -g 172.20.50.1
    INFO - Added route for destination=10.128.0.0/9 via=172.20.50.1
    INFO - New ip rule created with the id = 12003
    Can anyone else test adding a /8 netmask on a destination?
  • 5.  RE: CPPM - Adding network route error
    Posted Dec 04, 2014 07:38 AM
    Interesting , I'll try it on my lab and get back to you.
    I'm running the latest OS
  • 6.  RE: CPPM - Adding network route error
    Posted Dec 04, 2014 07:41 AM
    It worked on my lab with /8 with 6.4.3
  • 7.  RE: CPPM - Adding network route error
    Posted Dec 04, 2014 09:29 AM
    Thank for testing that.
    Funny thing is, there's another CPPM appliance in the install I'm doing. I was able to use the exact same command and it worked. Both cppm are on the same version too! 6.2.2.56893
    Hmmm.
  • 8.  RE: CPPM - Adding network route error
    Posted Dec 10, 2014 07:27 AM
    Not sure why I was unable to add that rule but the following is what I added in the end, which achieved the same result.
