CPPM and DUR in Aruba instant environment
  • 1.  CPPM and DUR in Aruba instant environment
    Posted Jul 07, 2020 12:25 PM
    Jiust setting up a ClearPass guest service in conjunction with Aruba Instant 8.7.0
    Want to implement  downloadable user roles  from cppm. Any Instant specific docn on this or is it just same as Mobility contoller enviorinment?
    Not much in the Instant 8.7.0.x User Guide
  • 2.  RE: CPPM and DUR in Aruba instant environment
    MVP GURU
    Posted Jul 07, 2020 03:06 PM
    See screenshot below and attached. Make sure download roles is checked. If you want to return a role and use the access defined on the IAP, under role assignment rules you should put a rule in saying that the "aruba-user-role is the role".
  • 3.  RE: CPPM and DUR in Aruba instant environment
    Posted Jul 08, 2020 03:55 AM
    Check this video for some hints. Note that between the 8.4 covered in the video and current versions the role-download options is available in GUI now (was CLI only in 8.4).
    Most important I'd say: Make sure time synchronization on both the AP and ClearPass is working; add the RADIUS server as a hostname, not as IP.
  • 4.  RE: CPPM and DUR in Aruba instant environment
    Posted Jul 08, 2020 11:16 AM
    Many thanks for this , very informative however .....
    I had the following
    wlan auth-server cppmnd.sharaz.info
    ip 192.168.1.21
    port 1812
    acctport 1813
    key
    nas-ip 192.168.1.20
    rfc5997 auth-only
    rfc3576
    cppm-rfc3576-port 5999
    service-type-framed-user 1x
    service-type-framed-user mac
    cppm username iap-admin password
    and all my auth stuff worked
    When I change the IP entry to be
    ip cppmnd.sharaz.info
    and do a commit apply;write m
    Then all auth queries to the cppm server stop , nothing appears there at
    all.
    Change config back to being an IP address ... authentications work.
    Each of the APs in the cluster have static addresses assigned and have an
    ipv4 DNS server address specified.
    All APs and ClearPass use the same NTP server
    A
