CPPM and EAP-TLS with CRL fallback
  • 1.  CPPM and EAP-TLS with CRL fallback
    Posted Nov 14, 2019 12:14 PM
    Hi all.
    I have a setup consisting in CPPM validating clients through EAP-TLS. Root CA is trusted by CPPM and validation is working fine without revocation checking ("Verify Certificate using OCSP:" to "None" in EAP TLS authentication method). Our organization has no OCSP but it has CRL verification. CRL URL is included in client certificates, but when we configure "Required(CRL fallback)" as certificate verification method clients stop validating. This is the output of the authentication failure:
    Error Code: 215
    Error Category: Authentication failure
    Error Message: TLS session error
    Alerts for this Request
    RADIUS Certificate does not contain OCSP URL
    EAP-TLS: fatal alert by server - unknown_ca
    TLS Handshake failed in SSL_read with error:14089086:SSL routines:ssl3_get_client_certificate:certificate verify failed
    eap-tls: Error in establishing TLS session
    The "Certificate does not contain OCSP URL" was expected, as the certificate has no OCSP URL in it, but it's puzzling finding "unknown_ca" as RADIUS response. We have included the CRL in "Administration » Certificates » Revocation Lists". It seems that the auth method is not doing "CRL fallback" at all.  Any idea of what's wrong with the setup?
  • 2.  RE: CPPM and EAP-TLS with CRL fallback
    Posted Nov 18, 2019 03:00 AM
    Does the CRL last check show a recent time and status is successful?
    I think working with Aruba Support is the best option at this moment, as OCSP is recommended and the most widely deployed verification method.
  • 3.  RE: CPPM and EAP-TLS with CRL fallback
    Posted Nov 18, 2019 04:10 AM
    Well, this is puzzling... after asking our sysadmin to revoke the certificate of the laptop we are using to test EAP-TLS, the authentication fails with the message "EAP-TLS: fatal alert by server - certificate_revoked" with "Verify Certificate using OCSP" set to None, so I guess I'm not understanding the whole point of having some kind of certificate verification if CPPM seems to do the checking anyway. I think I will open a case to the TAC. Thanks!
  • 4.  RE: CPPM and EAP-TLS with CRL fallback
    Posted Nov 18, 2019 10:18 AM
    CRL is always evaluated.
  • 5.  RE: CPPM and EAP-TLS with CRL fallback
    Posted Nov 18, 2019 11:19 AM
    Is good to know that. But then what's the point of having a "CRL fallback" option in EAP-TLS method in CPPM?
