CPPM and LDAP FreeIPA Integration Erorr
  • 1.  CPPM and LDAP FreeIPA Integration Erorr
    Posted Nov 29, 2016 05:28 AM
    Hi Guys,
    I Already Install CPPM and LDAP FreeIPA and i want integrate both with HPE Aruba 2530.
    But i got the message like below
    Any advice ?
    What shoud i do ?
    Kindly need your help
  • 2.  RE: CPPM and LDAP FreeIPA Integration Erorr
    Posted Mar 27, 2018 10:16 AM
    Did you find the solution for this? I am facing exactly same problem.
  • 3.  RE: CPPM and LDAP FreeIPA Integration Erorr
    Posted Mar 27, 2018 10:41 AM
    I believe the password should either be stored in Cleartext or Using NThash in the ldap server for mschapv2 authentication to work.
    May I recommend you to refer the below blog for freeIAP?
    http://firstyear.id.au/blog/html/2016/01/13/FreeRADIUS:_Using_mschapv2_with_freeipa.html
  • 4.  RE: CPPM and LDAP FreeIPA Integration Erorr
    Posted Mar 28, 2018 03:35 AM
    HI Saravanan,
    nice reading and it confirming my issue.
    i was thinking it must have something to do with the mschapv2 and i was right.
    is there any doc/guide on aruba about successful integration between clearpass and ldap? any ldap beside openIPA would do.
  • 5.  RE: CPPM and LDAP FreeIPA Integration Erorr
