last person joined: 9 hours ago
CPPM and MDM Integration - How to retrieve specific attributes from MDM
  • 1.  CPPM and MDM Integration - How to retrieve specific attributes from MDM
    Posted Sep 05, 2019 01:27 PM
    Hello Folks,
    I am in the process of integrating a XenMobile EMM/MDM with ClearPass; when polling the MDM server I am getting only a certain amount of attributes (14 from Android, 16 from Apple).
    My question is: How do I get more attributes?... I want to retrieve 3 specific attributes.
    The MDM has over 100 attributes from every endpoint but I am unable to retrieve more than those 14/16 mentioned.
    I heard that once you add the desired attributes to the -Dictionary Attributes- CPPM will poll them from the MDM, however I've done it and still not getting them.
    Any opinion suggestion will be highly appreciated.
    Sergio del Rosal.
  • 2.  RE: CPPM and MDM Integration - How to retrieve specific attributes from MDM
    Posted Sep 05, 2019 01:57 PM
    The attributes are normalized from all EMM providers. You cannot add or remove attributes.
  • 3.  RE: CPPM and MDM Integration - How to retrieve specific attributes from MDM
    Posted Sep 05, 2019 03:28 PM
    Thank you for your response Tim.
    Do you happen to know about any documentation regarding this Normalization process?
    I´ve read about it but I cannot seem to find detailed information.
    https://community.arubanetworks.com/t5/AAA-NAC-Guest-Access-BYOD/Tech-Note-ClearPass-Enterprise-Mobility-Management-Integration/ta-p/270204
    Thank you in advance for your help.
    Sergio del Rosal
