last person joined: 7 hours ago
CPPM Blacklist username
This thread has been viewed 22 times
  • 1.  CPPM Blacklist username
    Posted Mar 22, 2021 11:17 AM
    I am currently working on some cppm service about blacklisted username. I want to assign deny role on Role mapping profile, but I don't know how to filter out blacklisted username's authentication. it is not like IP or Mac which i could add them in static host list and then assign deny role by belongs_to_group.
    Could any one share alternative method to do such deny blacklisted username's authentication action.
    Shu Ming Tsang
  • 2.  RE: CPPM Blacklist username
    MVP GURU
    Posted Mar 22, 2021 12:11 PM
    What the source of authentication ?
    if it is AD, you can add a block ad group and make a rule if the user is member on this group,
    ACEP / ACMX #107 / ACDX #1281
  • 3.  RE: CPPM Blacklist username
    Posted Mar 22, 2021 09:35 PM
    dot1x auth and the source is AD. Just wanna know any method to do it on CPPM side rather than do it on AD side.
    Shu Ming Tsang
  • 4.  RE: CPPM Blacklist username
    MVP GURU
    Posted Mar 23, 2021 05:13 AM
    there is no easy solution i think...
  • 5.  RE: CPPM Blacklist username
    Posted Mar 23, 2021 05:30 AM
    What should work is adding the username in the Local Users or Guest Users database with a Role (Local Users) or Attribute, then add that database as an authorization source to your service. In role-mapping (or Enforcement) you can query the Local/Guest Users if the username is there and subject to being denied.
    Have not tested, but this should work.
