CPPM-C1000v upgrade from 6.8.0 to 6.9.x
This thread has been viewed 33 times
  • 1.  CPPM-C1000v upgrade from 6.8.0 to 6.9.x
    Posted Dec 16, 2020 10:33 AM
    Hello Guys,
    Do you have any idea if the C1000v supports or not the 6.9.0 release, or if it requires to move up to 6.8.8 prior to moving to the 6.9 release?
    Thanks.
  • 2.  RE: CPPM-C1000v upgrade from 6.8.0 to 6.9.x
    Posted Dec 16, 2020 09:51 PM
    Hey wireless-X,
    There is no specific alignment for a VM to a s/w release, so YES, a C1000v will support the 6.9.x code train, the assumption is you have followed the documented guide in terms of allocated resources required.
    https://www.arubanetworks.com/techdocs/ClearPass/CP_ReleaseNotes_6.9.0/Default.htm#SystemRequirements/VAReqs.htm
    You DO NOT have to be on 6.8.8 to go to 6.9.0, but there are some documented guidelines about upgrading to 6.9.
    https://www.arubanetworks.com/techdocs/ClearPass/CP_ReleaseNotes_6.9.0/Default.htm#UpgradeUpdate/UpgradingTo_6.9.htm%3FTocPath%3DUpgrade%2520and%2520Update%2520Information%7CUpgrading%2520to%2520ClearPass%2520Policy%2520Manager%25206.9%7C_____0
    https://www.arubanetworks.com/techdocs/ClearPass/CP_ReleaseNotes_6.9.0/Default.htm#SystemRequirements/New-Install-Caveats.htm%3FTocPath%3DSystem%2520Requirements%2520for%2520ClearPass%2520Policy%2520Manager%25206.9%7C_____6
    HTH
    Danny Jump
    "Passionate about CPPM"
  • 3.  RE: CPPM-C1000v upgrade from 6.8.0 to 6.9.x
    Posted Dec 17, 2020 07:29 AM
    Thanks for help
    Do we have any specific input/output operations per second (IOPS) values that should be set?
  • 4.  RE: CPPM-C1000v upgrade from 6.8.0 to 6.9.x
    Posted Dec 17, 2020 03:28 PM
    These numbers still work
    https://www.arubanetworks.com/techdocs/ClearPass/CP_ReleaseNotes_6.8.0/Content/SystemRequirements/ESXiRequirements.htm
    Danny Jump
