CPPM can change port name on Aruba switch?
  • 1.  CPPM can change port name on Aruba switch?
    Posted Sep 20, 2019 04:13 AM
    I have a q.
    Is it possible to configure a poilcy that auto update the port name on the Aruba switch after device authenticated successfully?
    If not, I wish the R&D will do that.
  • 2.  RE: CPPM can change port name on Aruba switch?
    Posted Sep 20, 2019 04:49 AM
    Not possible via RADIUS but could be possible if switch APIs can be leveraged.
  • 3.  RE: CPPM can change port name on Aruba switch?
    Posted Sep 20, 2019 05:48 AM
    So i suggest R&D will work for a simple solution instead of API.
    In general, SNMP can do that, so why not develop a rule for it?
  • 4.  RE: CPPM can change port name on Aruba switch?
    Posted Sep 20, 2019 07:39 AM
    You can make a new feature request at the innovation zone:
    https://innovate.arubanetworks.com/
    Other people can vote on these requests, if there is a lot of demand for a certain item, they might be convinced to implement it.
  • 5.  RE: CPPM can change port name on Aruba switch?
    Posted Sep 20, 2019 10:01 AM
    Changing switch configurations is an NMS function. We don't implement NMS functions in CPPM.
  • 6.  RE: CPPM can change port name on Aruba switch?
    Posted Sep 20, 2019 02:39 PM
    I agree with Tim.  You should see what Central or AirWave can do to help with this.
