CPPM Change Guest Vlan after authentication
  • 1.  CPPM Change Guest Vlan after authentication
    Posted Nov 25, 2014 11:17 AM
    Hi guys,
    I'm new to CPPM so there are somethings that I'm still learning.
    I would like to change a specific user from the initial vlan.
    Workflow:
    User associates to the open Guest SSID, gets an IP and authenticates. After that, based on that user role I would like to change his VLAN.
    At this momment I only have 1 service for Guest Authentication. I believe that to achieve this I'll have to create a mac auth service.
    Can someone help me to achieve this?
  • 2.  RE: CPPM Change Guest Vlan after authentication
    Posted Nov 25, 2014 11:30 AM
    You can create the mac caching using the CPPM Guest Mac Auth Template
    Once you do that on the Guest Mac auth enforcement policy you can create a rule that if the device has a particular mac address you can send another VLAN
  • 3.  RE: CPPM Change Guest Vlan after authentication
    Posted Nov 25, 2014 11:32 AM
    There is a fundamental issue with changing a user's vlan on a captive portal.  The number one reason is that the client normally does not re-ip unless it is forcefully disconnected.  This creates client-side confusion when the user's wifi drops.  Is there a reason why a guest's vlan cannot stay on the same VLAN that we have to work around?
  • 4.  RE: CPPM Change Guest Vlan after authentication
    Posted Nov 25, 2014 01:04 PM
    cjoseph is right about that...
  • 5.  RE: CPPM Change Guest Vlan after authentication
    Posted Nov 25, 2014 05:23 PM
    Well this is a requirement of a costumer.
    I do agree with you that it may be unnecessary.
    It is not clear to me though how can I force a guest with role XYZ to be assign into a specific vlan after the authentication.
    I wouldn't like to do that based on the MAC address but on the user role.
    Thank you guys!
  • 6.  RE: CPPM Change Guest Vlan after authentication
    Posted Nov 25, 2014 06:46 PM
    send a COA.
  • 7.  RE: CPPM Change Guest Vlan after authentication
    Posted Nov 25, 2014 06:51 PM
    You should inform the customer that there will be inconsistent client behavior.
  • 8.  RE: CPPM Change Guest Vlan after authentication
    Posted Nov 25, 2014 07:34 PM
    I understand that.
    I would like to test it anyway... just for learning purporses...
    Can anyone point me some example for this?
    Thanks a lot for your time and pacience
  • 9.  RE: CPPM Change Guest Vlan after authentication
    Posted Nov 25, 2014 08:57 PM
    Try the following :
    1- Using the ClearPass templates create a Guest Mac Auth
    2- Then create an enforcement profile and use the Aruba attribute Aruba-user-VLAN then add the VLAN you want that user to get
    3- Create another enforcement profile and use the Aruba attribute Aruba-user-role then add the Role you have created on the controller that points the user to the guest captive portal registration page
    Then do the following:
    Using this logic the device doesn't have to change VLANs instead it stays using the same VLAN at the Captive Portal Stage and after it completes registration
    Note: I haven't tested this out so this may or may not work.
  • 10.  RE: CPPM Change Guest Vlan after authentication
    Posted Nov 26, 2014 01:56 PM
    Thank you for your guidence.
    Solved! :)
