CPPM - Client did not complete EAP transaction
This thread has been viewed 19 times
  • 1.  CPPM - Client did not complete EAP transaction
    Posted Jan 02, 2019 08:49 AM
    I'm getting this message ONLY with iOS devices. This is the scenario:
    ClearPass 6.7.8.109113
    802.1X Aruba Wireless Service
    Authentication Source: Active Directory
    Authentication Method: EAP-PEAP/EAP-MSCHAPv2
    ClearPass joined in Domain
    RADIUS Certificate generated from Windows CA
    CA certificate added to Trust list
    When iOS device connects everything looks fine on Access Tracker, but after a few seconds I get this message and TIMEOUT Alert for this Request. If the iOS device is rebooted I can connect without problem, but after a couple of hours I get this error again.
  • 2.  RE: CPPM - Client did not complete EAP transaction
    Posted Jan 02, 2019 10:50 AM
    How are you configuring the device supplicants?
  • 3.  RE: CPPM - Client did not complete EAP transaction
    Posted Jan 02, 2019 01:10 PM
    Well, on iOS device we're letting the device set the parameters automatically.
    1. Connect to SSID 802.1X
    2. Enter user credentials
    3. Trust the certificate
    4. Connected
    Windows computers that is on domain we set these parameters via GPO, and when someone is not on domain we set manually (Win7) or connect like iOS (Win10).
  • 4.  RE: CPPM - Client did not complete EAP transaction
    Posted Jan 02, 2019 03:04 PM
    You should not be using a tunneled EAP method with manual client configuration. I would recommend moving to EAP-TLS or using a supplicant configuration utility.
  • 5.  RE: CPPM - Client did not complete EAP transaction
    Posted Jan 02, 2019 03:12 PM
    Thanks Capalli, I agree with you.
    But this is the scenario that we need to work today and we can't change anything now. To do EAP-TLS on Smartdevices the customer will need to buy Onboard licenses.
    I think this is an isolated problem with iOS devices. Another OS's works fine.
    Already openned a TAC, but I was hopen that someone here already got throught this.
  • 6.  RE: CPPM - Client did not complete EAP transaction
    Posted Jan 02, 2019 03:14 PM
    It's behaving as designed since the supplicant is not configured. This is the issue with using legacy EAP methods on unmanaged devices.
  • 7.  RE: CPPM - Client did not complete EAP transaction
    Posted Jan 02, 2019 03:22 PM
    Yes but why sometimes with the same device works? After a reboot or forgetting the SSID we can connect again.
    With any other type of supplicant, manually or via GPO configured, we can connect without any problems. Android, Windows, Linux is OK. Only iOS devices are getting this issue.
  • 8.  RE: CPPM - Client did not complete EAP transaction
    Posted Jan 02, 2019 03:24 PM
    Because they're not properly configured.
  • 9.  RE: CPPM - Client did not complete EAP transaction
    Posted Jan 02, 2019 03:28 PM
    Ok. Assume that they're configured incorrectly, the only solution is use onboard on this kind of device?
    If the customer configure a FreeRadius or Microsoft NPS to authenticate this devices this issue not occurs. Why only with ClearPass? What's the difference?
  • 10.  RE: CPPM - Client did not complete EAP transaction
    Posted Jan 02, 2019 03:45 PM
    Onboard, supplicant configuration utility or manual configuration. The issues will occur on any RADIUS platform. It is not a ClearPass issue.
  • 11.  RE: CPPM - Client did not complete EAP transaction
    Posted Jan 02, 2019 03:59 PM
    I've tested. This issue occurs only with ClearPass.
  • 12.  RE: CPPM - Client did not complete EAP transaction
    Posted Jan 02, 2019 04:05 PM
    The topology or server identities likely differ.
  • 13.  RE: CPPM - Client did not complete EAP transaction
    Posted Jan 02, 2019 04:13 PM
    I've tested on Microsoft NPS. The certificates was issued by the same Windows CA Server (They have 1 CA Server only).
