CPPM Cluster Design if Publisher and Subscrib%0D%0Aer in different Locations
  • 1.  CPPM Cluster Design if Publisher and Subscrib%0D%0Aer in different Locations
    Posted Jan 30, 2017 07:29 AM
    Hi The publisher and subscriber will be in different locations, and there is L2 link between the two sites. So can I use Eth0 as a cluster probe interface, and Eth1 for data and authentication? Or its better to use only Eth0 for all purposes?
  • 2.  RE: CPPM Cluster Design if Publisher and Subscrib%0D%0Aer in different Locations
    Posted Jan 30, 2017 07:38 AM
  • 3.  RE: CPPM Cluster Design if Publisher and Subscrib%0D%0Aer in different Locations
    Posted Jan 30, 2017 08:13 AM
    Nothing related to interfaces design in this document......
  • 4.  RE: CPPM Cluster Design if Publisher and Subscrib%0D%0Aer in different Locations
  • 5.  RE: CPPM Cluster Design if Publisher and Subscrib%0D%0Aer in different Locations
    MVP EXPERT
    Posted Jan 30, 2017 08:26 AM
    Hey, the configuration for each interface is detailed below.
    Management Port : The Management port (ethernet 0) provides access for cluster administration and appliance maintenance using the WebUI, CLI, or internal cluster communication. This configuration is mandatory.
    Data Port: The Data port (ethernet 1) provides a point of contact for RADIUS, TACACS+, Web authentication, and other dataplane requests. This configuration is optional. If this port is not configured, requests are redirected to the Management port.
