CPPM CP Guest - HTTP instead of HTTPS login
  • 1.  CPPM CP Guest - HTTP instead of HTTPS login
    Posted Mar 22, 2016 02:13 AM
    Hello folk,
    Hope all of you doing great
    Can we configure CP on CPPM using http instead of https for guest access.
    appreciate your input
  • 2.  RE: CPPM CP Guest - HTTP instead of HTTPS login
    Posted Mar 22, 2016 02:23 AM
    Guest> Configuration> Authentication
  • 3.  RE: CPPM CP Guest - HTTP instead of HTTPS login
    Posted Mar 22, 2016 02:59 AM
    Hi Colin,
    First all of thanks for your promptness, I did it without positive result.
    And I also tried to modify the login page on Controller itself from http to https, but when I did that it didn't work.
  • 4.  RE: CPPM CP Guest - HTTP instead of HTTPS login
    Posted Mar 22, 2016 08:05 AM
    What does your captive portal authentication profile look like on the controller?  It should have a URL that points to the http://  version of the page on ClearPass...
  • 5.  RE: CPPM CP Guest - HTTP instead of HTTPS login
    Posted Mar 22, 2016 09:11 AM
    I aware about this point, when I change it from https to http, it stop working and the webpage did not display, already the service on CPPM working and reachable, I test it using telnet <cppm> 80 from guest machine.
    please find the attachment
    Many thanks for your support
  • 6.  RE: CPPM CP Guest - HTTP instead of HTTPS login
    Posted Mar 24, 2016 04:39 AM
    Hello All,
    appreciate your inputs.
  • 7.  RE: CPPM CP Guest - HTTP instead of HTTPS login
    Posted Mar 24, 2016 04:42 AM
    The "Login Page" parameter should not point to an https:// page.  It should point to an http:// page...
  • 8.  RE: CPPM CP Guest - HTTP instead of HTTPS login
    Posted Mar 24, 2016 05:22 AM
    Hi Colin,
    I already change it to http, and it did not work, it did not appear the registration page totally.
    http with TCP port 80 is okay with telnet test, but the page did not appears.
    Any more suggestions.
    Many thanks,
  • 9.  RE: CPPM CP Guest - HTTP instead of HTTPS login
    Posted Mar 24, 2016 05:40 AM
    I think you should open a case with TAC.  I am out of ideas..
  • 10.  RE: CPPM CP Guest - HTTP instead of HTTPS login
    Posted Mar 24, 2016 08:24 AM
    Did you also check the box 'use http' as well?  Your screenshot below.
  • 11.  RE: CPPM CP Guest - HTTP instead of HTTPS login
    Posted Mar 25, 2016 12:57 AM
    Good morning Yes I checked this check box, and it didn't work
    #AirheadsMobile
  • 12.  RE: CPPM CP Guest - HTTP instead of HTTPS login
    Posted Mar 25, 2016 10:44 AM
    Please open a TAC case, so that they can find out what your problem is.
  • 13.  RE: CPPM CP Guest - HTTP instead of HTTPS login
    Posted Apr 19, 2016 06:12 AM
    Many thanks guys, I solve it, it was redirect ACL for http traffic .
    Realy thanks for your great inputs.
