CPPM - Differentiating authentication requests coming from iPads
  • 1.  CPPM - Differentiating authentication requests coming from iPads
    Posted Nov 10, 2012 01:31 PM
    As one part of a simple ClearPass solution I'm trying to implement, my customer is requesting a "BYOD" SSID that will allow any unknown devices to connect, given proper AD credentials.  However:
    - laptops must also pass the OnGuard java applet checks (no problem)
    - iPads must be allowed on the same SSID (?)
    I know this could be taken care of using the Onboard solution but the customer does not want Onboard or Profile.  I need to find a method to differentiate the access requests coming from iPads so they can bypass the applet as it is not supported by iOS.  One idea I wanted to try was to just allow access if the authentication method was EAP-TLS.  What I've read so far tells me that this would require TLS certificate provisioning on the iPad prior to authentication.  Is there a more simple solution I'm missing for the CPPM to just recognize an iPad sourced request?
  • 2.  RE: CPPM - Differentiating authentication requests coming from iPads
    Posted Nov 10, 2012 08:26 PM
    Nevermind.  I just learned about DHCP Fingerprinting from the Aruba VRD webpage.
  • 3.  RE: CPPM - Differentiating authentication requests coming from iPads
    Posted Nov 12, 2012 06:44 AM
    If we can do dhcp fingerprint in the controller what is the point to have clearpass?
    Besides the guest provisioning part?
    I was under the impression that blocking end-point devices should be done using the profiler in the clearpass.
  • 4.  RE: CPPM - Differentiating authentication requests coming from iPads
    Posted Nov 12, 2012 12:43 PM
    Matching the fingerprint just enables you to recognize the device type.. that doesn't put it on par with a full-fledged profiling solution :)
  • 5.  RE: CPPM - Differentiating authentication requests coming from iPads
    Posted Nov 12, 2012 12:51 PM
    Clearpass allows you to use the manufacturer and/or OS type as a decision variable during authentication.  The controller will assign a different role during association/authentication, but does not offer the rich policy decisionmaking combinations that is available in clearpass.  In addition, ClearPass is multivendor, so WLAN or LAN manufacturers who are not OS-aware can also leverage the the decisionmaking in clearpass that was not available previously.
  • 6.  RE: CPPM - Differentiating authentication requests coming from iPads
    Posted Nov 13, 2012 03:54 AM
    this sounds like a sales pitch :-)
    since DHCP fingerprinting can assign roles it should sofice for me.
  • 7.  RE: CPPM - Differentiating authentication requests coming from iPads
    Posted Nov 13, 2012 06:25 AM
    shpapy,
    It is a sales pitch for whoever needs the solution.  DHCP fingerprinting alone only allows you to change the role of a user based on the OS of the device.  That is good for users like yourself who only want to make a decision based on OS.
     If you have to combine it with other things like teacher+ipad,  and student+ipad you need Clear Pass Policy Manager.
  • 8.  RE: CPPM - Differentiating authentication requests coming from iPads
    Posted Nov 13, 2012 07:37 AM
    so its more like an extended functionality.
    got it.
  • 9.  RE: CPPM - Differentiating authentication requests coming from iPads
    Posted Nov 14, 2012 09:03 AM
    i have added the following under services-->enfo.
    This is working now and blocked Samsung S3 and apple devices.
    Is this a good way to implement or should I use profiler or a different option, I have full clearpass license.
    Any suggestions will be gladly appreciated.
    3.(Connection:Client-Mac-Vendor EQUALS Murata Manufacturing Co., Ltd.)[Deny Access Profile]
    4.(Connection:Client-Mac-Vendor EQUALS Apple, Inc.)
  • 10.  RE: CPPM - Differentiating authentication requests coming from iPads
    Posted Nov 19, 2012 07:55 AM
    you are doing this on clearpass now, or the controller?
    because i thought that user derivation (i.e. DHCP finger printing) doesnt work with dot1x? also doesnt the above block iPads too?
  • 11.  RE: CPPM - Differentiating authentication requests coming from iPads
    Posted Nov 19, 2012 07:57 AM
    im not using user role derivation in the controller i do it in the clearpass based on vendor mac.
    the controller is not a part of the setup for the blocking.
