CPPM: Drop specific wired ports in a different service
  • 1.  CPPM: Drop specific wired ports in a different service
    Posted Jun 16, 2022 08:44 AM
    Hi All,
    I am wondering if it is possible to drop endpoints connecting to a specific set of network ports into a different service in ClearPass. Does anyone know if this is possible? I was thinking about some sort of static list with switch port numbers defined, but I can't seem to make such a list in ClearPass.
    Lex
  • 2.  RE: CPPM: Drop specific wired ports in a different service
    Posted Jun 16, 2022 09:59 PM
    You would need to look at how the incoming radius attributes are different for those ports and use the attributes to tag a role in CPPM and write an enforcement policy keying on that role.  Or just write an enforcement policy looking for those radius attributes.
  • 3.  RE: CPPM: Drop specific wired ports in a different service
    Posted Jun 17, 2022 03:04 AM
    I was thinking about the same using role-mapping and will try something like:
    (Connection:NAD-IP-Address  EQUALS  <IP of switch>) AND  (Radius:IETF:NAS-Port-Id  EQUALS  <ID of port>)  >> Role X
    Then in enforcement: If Role X > Enforcement Y
    Thanks for your reply, I will test this. However, there is no way I can define a list of ports? Using this, I have to create a separate role mapping condition for every port I want to include :/
    Lex
  • 4.  RE: CPPM: Drop specific wired ports in a different service
    Posted Jun 17, 2022 06:04 AM
    Can you describe what you are trying to do so that the community can come up with a suggestion?  You mentioned an exception for 4 ports and what I proposed does not scale for a large number of exceptions
  • 5.  RE: CPPM: Drop specific wired ports in a different service
    Posted Jun 17, 2022 08:26 AM
    Specifically, the method I described works if you need to treat a couple ports differently, but it will not work large-scale.  An alternative is to try a "colorless" ports approach where the posture of a device is treated differently based on what you know about that device and how it authenticates, rather than securing individual ports differently.
