CPPM - DUR - Parse Error - Invalid Context
  • 1.  CPPM - DUR - Parse Error - Invalid Context
    Posted Aug 04, 2019 09:57 PM
    I'm having an issue with (what I thought) was a simple downloadable user role. In this example, I'm passing two DURs from ClearPass to an Aruba 2930F switch:
    • DUR-DHCP-Only
    • DUR-Allow-All
    The allow all role is working correctly:
    CPPM:
    class ipv4 IP-ANY-ANY
    match ip any any
    exit
    policy user Allow-All-ACL
    class ipv4 IP-ANY-ANY action permit
    exit
    aaa authorization user-role name DUR-Data-Allow-All
    policy Allow-All-ACL
    vlan-name Lab-Network
    exit
    Switch:
    I 08/04/19 18:08:14 00435 ports: port 8 is Blocked by AAA
    0000:01:50:23.34 UMIB tRadiusR:Received cppm downloadable user role vsa for
       client with request-id 60 and assigned user role is :
       Aruba_DUR_Data_Allow_All-3016-11
    0000:01:50:23.34 UMIB mdcaCtrl:New node is created for the downloadable user
       role Aruba_DUR_Data_Allow_All-3016-11
    0000:01:50:23.34 UMIB mdcaCtrl:DUR Client with request-id 60 is added to waiting
       queue for downloadable user role Aruba_DUR_Data_Allow_All-3016-11 in INITIAL
       state
    0000:01:50:23.34 UMIB mdcaCtrl:Posting event to cppm task to  download the
       userRole Aruba_DUR_Data_Allow_All-3016-11
    0000:01:50:23.44 UMIB tRadiusR:Received cppm downloadable user role vsa for
       client with request-id 61 and assigned user role is :
    0000:01:50:23.44 UMIB mdcaCtrl:DUR Client with request-id 61 is added to waiting
       DOWNLOADING state
    0000:01:50:25.51 UMIB mcppmTask:Download of userRole
       Aruba_DUR_Data_Allow_All-3016-11 is success
    0000:01:50:25.51 UMIB mcppmTask:Parsing of downloaded userRole
    0000:01:50:25.53 UMIB mcppmTask:Copying downloaded userRole
       Aruba_DUR_Data_Allow_All-3016-11 to RamFs is success
    0000:01:50:25.53 UMIB mdcaCtrl:Removing DUR Client with request-id 60 for
       downloadable user role Aruba_DUR_Data_Allow_All-3016-11 from waiting queue as
       the role is downloaded
    0000:01:50:25.53 UMIB mdcaCtrl: Sending message to authentication task for
    0000:01:50:25.53 UMIB mdcaCtrl:Removing DUR Client with request-id 61 for
    0000:01:50:25.53 UMIB mdcaCtrl:Removing previous downloadable user role version
       Aruba_DUR_Data_Allow_All-3016-10_7Z4q as no clients are mapped to that
       version
    0000:01:50:25.53 UMIB mdcaCtrl: Deleting the downloadable user role
       Aruba_DUR_Data_Allow_All-3016-10 from config record
    0000:01:50:25.58 UMIB mWebAuth:added new dca client f0def1-7b4652 for new client
       port 8.
    0000:01:50:25.58 UMIB mWebAuth:Client Mac F0DEF1-7B4652, accessMode MacAuth
    I 08/04/19 18:08:16 00076 ports: port 8 is now on-line
    0000:01:50:25.59 UMIB m8021xCtrl:removing dca client f0def1-7b4652 for port 8.
    0000:01:50:25.59 UMIB m8021xCtrl:added new dca client f0def1-7b4652 for new
       client port 8.
    0000:01:50:25.59 UMIB m8021xCtrl:Client Mac F0DEF1-7B4652, accessMode 8021x
    I 08/04/19 18:08:16 00001 vlan: Default virtual LAN enabled (1 times in 60
                seconds)
    I 08/04/19 18:08:16 00002 vlan: Default virtual LAN disabled (1 times in 60
                seconds)
    The DUR-DHCP-Only role however is not working correctly. I get an error that the role contains non role commands. I've made sure to 1) eliminate any additional spacing or extra characters and 2) have confirmed that the role works successfully when deployed locally on the switch.
    Does anyone have any ideas here? There must be something simple that I've overlooked. Switch is running 16.08.0005.
    CPPM:
    match ip any any
    class ipv4 DHCP
    match udp any any eq 67
    exit
    policy user DHCP-Only-ACL
    class ipv4 DHCP action permit
    class ipv4 IP-ANY-ANY action deny
    exit
    aaa authorization user-role name DUR-DHCP-Only
    policy DHCP-Only-ACL
    exit
    Switch:
    I 08/04/19 18:10:35 00435 ports: port 8 is Blocked by AAA
    0000:01:52:44.19 UMIB tRadiusR:Received cppm downloadable user role vsa for
       client with request-id 62 and assigned user role is :
       Aruba_DUR_DHCP_Only-3017-5
    0000:01:52:44.19 UMIB mdcaCtrl:New node is created for the downloadable user
       role Aruba_DUR_DHCP_Only-3017-5
    0000:01:52:44.19 UMIB mdcaCtrl:DUR Client with request-id 62 is added to waiting
       queue for downloadable user role Aruba_DUR_DHCP_Only-3017-5 in INITIAL state
    0000:01:52:44.19 UMIB mdcaCtrl:Posting event to cppm task to  download the
       userRole Aruba_DUR_DHCP_Only-3017-5
    0000:01:52:44.25 UMIB tRadiusR:Received cppm downloadable user role vsa for
       client with request-id 63 and assigned user role is :
    0000:01:52:44.25 UMIB mdcaCtrl:DUR Client with request-id 63 is added to waiting
       queue for downloadable user role Aruba_DUR_DHCP_Only-3017-5 in DOWNLOADING
       state
    0000:01:52:46.34 UMIB mcppmTask:Download of userRole Aruba_DUR_DHCP_Only-3017-5
       is success
    0000:01:52:46.34 UMIB mcppmTask:Parsing of downloaded userRole
       Aruba_DUR_DHCP_Only-3017-5 is Failed with reason PARSE_ERROR_INVALID_CONTEXT
    0000:01:52:46.34 UMIB mdcaCtrl: Sending message to authentication task for
    0000:01:52:46.34 UMIB mdcaCtrl:Removing DUR Client with request-id 62 for
       downloadable user role Aruba_DUR_DHCP_Only-3017-5 from waiting queue as role
       parsing failed
    0000:01:52:46.34 UMIB mdcaCtrl:Removing DUR Client with request-id 63 for
       parsing failed
    0000:01:52:46.34 UMIB mWebAuth:macAuth Deauthenticating client F0DEF17B4652 on
       port 8, downloaded user role Aruba_DUR_DHCP_On... is not valid as it contains
       non user role commands.
    W 08/04/19 18:10:37 05630 dca: Faulty line: class ipv4 DHCP
    W 08/04/19 18:10:37 05619 dca: macAuth Deauthenticating client F0DEF17B4652 on
                contains non user role commands.
    0000:01:52:46.35 UMIB m8021xCtrl:8021X Deauthenticating client F0DEF17B4652 on
    W 08/04/19 18:10:37 05619 dca: 8021X Deauthenticating client F0DEF17B4652 on
    If the role is assigned locally, I get no errors:
    Aruba-Lab-SW1(config)# class ipv4 IP-ANY-ANY
    Aruba-Lab-SW1(config-class)# match ip any any
    Aruba-Lab-SW1(config-class)# class ipv4 DHCP
    Aruba-Lab-SW1(config-class)# match udp any any eq 67
    Aruba-Lab-SW1(config-class)# exit
    Aruba-Lab-SW1(config)# policy user DHCP-Only-ACL
    Aruba-Lab-SW1(policy-user)# class ipv4 DHCP action permit
    Aruba-Lab-SW1(policy-user)# class ipv4 IP-ANY-ANY action deny
    Aruba-Lab-SW1(policy-user)# exit
    Aruba-Lab-SW1(config)# aaa authorization user-role name DUR-DHCP-Only
    Aruba-Lab-SW1(user-role)# policy DHCP-Only-ACL
    Aruba-Lab-SW1(user-role)# vlan-name Lab-Network
    Aruba-Lab-SW1(user-role)# exit
    For further context, the Allow-All role:
    Aruba-Lab-SW1(config)# show port-access clients detailed
     Port Access Client Status Detail
      Client Base Details :
       Port            : 8                     Authentication Type : 802.1x
       Client Status   : authenticated         Session Time        : 11 seconds
       Client name     : VMLAB\Ryan            Session Timeout     : 0 seconds
       MAC Address     : f0def1-7b4652
       IP              : 169.254.16.6
       Auth Order      : Not Set
       Auth Priority   : Not Set
       LMA Fallback    : Disabled
    Downloaded user roles are preceded by *
     User Role Information
       Type                              : downloaded
       Reauthentication Period (seconds) : 0
       Cached Reauth Period (seconds)    : 0
       Logoff Period (seconds)           : 300
       Untagged VLAN                     : 20
       Tagged VLANs                      :
       Captive Portal Profile            :
       Policy                            : Allow-All-ACL_Aruba_DUR_Data_Allow_All-3016-11
    Statements for policy "Allow-All-ACL_Aruba_DUR_Data_Allow_All-3016-11"
    policy user "Allow-All-ACL_Aruba_DUR_Data_Allow_All-3016-11"
         10 class ipv4 "IP-ANY-ANY_Aruba_DUR_Data_Allow_All-3016-11" action permit
       exit
    Statements for class IPv4 "IP-ANY-ANY_Aruba_DUR_Data_Allow_All-3016-11"
         10 match ip 0.0.0.0 255.255.255.255 0.0.0.0 255.255.255.255
       exit
       Tunnelednode Server Redirect      : Disabled
       Secondary Role Name               :
       Device Attributes                 : Disabled
    And the DHCP-Only role:
    Aruba-Lab-SW1(eth-8)# show port-access clients detailed
       Client Status   : initial role failed   Session Time        : 0 seconds
       Client name     :                       Session Timeout     : 0 seconds
       IP              : n/a
       Port            : 8                     Authentication Type : mac-based
       Client Status   : initial role failed   Session Time        : 4 seconds
       Client Name     : f0def17b4652          Session Timeout     : 0 seconds
       IP              : n/a
  • 2.  RE: CPPM - DUR - Parse Error - Invalid Context
    Posted Aug 16, 2019 08:55 PM
    So what finally worked for me was to put everything in quotes:
    Allow-All:
    class ipv4 "IP-ANY-ANY"
    match ip any any
    exit
    policy user "Allow-All-ACL"
    10 class ipv4 "IP-ANY-ANY" action permit
    exit
    aaa authorization user-role name "DUR-Data-Allow-All"
    policy "Allow-All-ACL"
    reauth-period 28800
    vlan-name "LAB-Corp"
    exit
    And DHCP-Only:
    match ip any any
    exit
    class ipv4 "DHCP"
    exit
    policy user "DHCP-Only-ACL"
    10 class ipv4 "DHCP" action permit
    20 class ipv4 "IP-ANY-ANY" action deny
    exit
    aaa authorization user-role name "DUR-Data-DHCP-Only"
    policy "DHCP-Only-ACL"
    reauth-period 28800
    exit
  • 3.  RE: CPPM - DUR - Parse Error - Invalid Context
    Posted Sep 03, 2019 09:42 PM
    Just wondering if all you were missing was an "exit" line in the first class definition:
    match ip any any
    exit <-- This line missing? class ipv4 DHCP match udp any any eq 67 exit
