CPPM - Failed to join domain: failed to connect to AD: Operations error
  • 1.  CPPM - Failed to join domain: failed to connect to AD: Operations error
    Posted May 26, 2015 09:03 PM
    When trying to Join ClearPass to an AD domain it is faling due to  "Operations error"
    Join domain failed
    Adding host to AD domain...
    INFO - Fetched REALM 'XXX.LOCAL' from domain FQDN
    'YYY.XXX.local'
    INFO - Fetched the NETBIOS name 'EU'
    INFO - Creating domain directories for 'EU'
    Enter -USER's password:
    >>>>  Failed to join domain: failed to connect to AD: Operations error <<<<
    INFO - Restoring smb configuration
    INFO - Restoring krb5 configuration file
    INFO - Deleting domain directories for 'EU'
    ERROR - ServerName failed to join the domain XXX.LOCAL
    with domain controller as YYY.XXX.local
    Join domain failed
    ClearPass has connectivity to the DC and the FQDN resolves to the correct IP@ and finds the NETBIOS name correctly.
    I am wondering if the firewall might be blocking port 389 , is there a CLI command I could use to test this port ?
    Thank you,
    David Sanchez
  • 2.  RE: CPPM - Failed to join domain: failed to connect to AD: Operations error
    Posted May 26, 2015 09:05 PM
    You can test authentication against a domain by using:
     auth -u <username> -n <domain NETBIOS name>
  • 3.  RE: CPPM - Failed to join domain: failed to connect to AD: Operations error
    Posted May 27, 2015 01:22 AM
    Hello Tim,
    Thank you for your reply.
    I've tried that command already and didn't work. For it to be used  CPPM needs to be part of the domain first, and I am stuck in the process of joining the AD.
    I am awaiting to confirm port 389 by the firewall team and will post the outcome.
    DS
