CPPM MAC Auth with Cisco 3650 WLC
  • 1.  CPPM MAC Auth with Cisco 3650 WLC
    Posted May 31, 2016 11:37 PM
    Has anyone done this successfully?   We found out that the password sent by Cisco is not matching the username (MAC addr w/o delimiter) and caused MAC auth to break.  Thanks
  • 2.  RE: CPPM MAC Auth with Cisco 3650 WLC
    Posted Jun 01, 2016 05:07 AM
    Do you have Mac filtering enabled under your Layer 2 tab?
    Can you post what's in the access tracker?
  • 3.  RE: CPPM MAC Auth with Cisco 3650 WLC
    Posted Jun 01, 2016 05:15 AM
    Forgot to mention, yes it definitely works. Lots of people have this setup working.
  • 4.  RE: CPPM MAC Auth with Cisco 3650 WLC
    Posted Jun 01, 2016 06:21 AM
    Can you please share your switch interface config ?
    Get Outlook for iOS
  • 5.  RE: CPPM MAC Auth with Cisco 3650 WLC
    Posted Jun 01, 2016 06:31 AM
    Here's the access tracker output:
    Error Code: 209
    Error Category: Authentication failure
    Error Message: No password in request
    Alerts for this Request -
       RADIUS: [Endpoints Repository] - localhost: User not found.
    MAC-AUTH: Password in request doesn't match username. Not attempting MAC authentication
    Cannot select appropriate authentication method
    Will need to get sh run from the end user, stay tuned and thank you very much :)
  • 6.  RE: CPPM MAC Auth with Cisco 3650 WLC
    Posted Jun 01, 2016 07:18 AM
    Do you have MAC Filtering enabled on your WLAN > Layer 2 setting?
    From CPPM what is the Username of the request in the access tracker. It should be the clients MAC address if the above is enabled.
    Have you set a layer 2 security? Try "none" as per the image above.
    Cheers
    James
  • 7.  RE: CPPM MAC Auth with Cisco 3650 WLC
    Posted Jun 06, 2016 08:32 PM
    Here's the WLAN interface config:
    wlan ISE 3 ISE
    aaa-override
    accounting-list ise-acct
    client vlan Wireless-HOME
    no exclusionlist
    ip access-group web ISE-ACL
    ip dhcp required
    ip dhcp server 10.180.1.193
    mac-filtering ise-mac
    nac
    no security wpa
    no security wpa akm dot1x
    no security wpa wpa2
    no security wpa wpa2 ciphers aes
    security dot1x authentication-list ise-auth
    security web-auth
    security web-auth parameter-map ISE-MAP
    session-timeout 1800
    no shutdown
  • 8.  RE: CPPM MAC Auth with Cisco 3650 WLC
    Posted Jun 07, 2016 03:20 AM
    We have tried both the followings in Cisco to set the username format with no luck
    mab request format attribute 1 groupsize 2 separator : lowercase
    mab request format attribute 1 groupsize 12 separator : lowercase
    http://www.cisco.com/c/en/us/td/docs/ios-xml/ios/sec_usr_aaa/configuration/15-e/sec-usr-aaa-15-e-book/sec-usr-config-mab-usrname-pwd.html
  • 9.  RE: CPPM MAC Auth with Cisco 3650 WLC
    Posted Jun 07, 2016 04:44 AM
    What about Radius MAC Delimiter? Default is something other than this..
