CPPM Missing Configuration --> Security
  • 1.  CPPM Missing Configuration --> Security
    Posted Jun 16, 2017 07:34 AM
    I am trying to setup a RADIUS connection between out CPPM and the company's RADIUS servers.  In the directions I am finding, they say in CPPM to go to Configuration -> Security.
    I do not show a Security section listed under Configuration in the CPPM menu on the left.   So, not sure where to go from here.
  • 2.  RE: CPPM Missing Configuration --> Security
    Posted Jun 16, 2017 08:09 AM
    Could you share the document which you are following, we generally add Radius server in Configuration » Authentication » Sources tab.
    Controller /IAP in Configuration » Network » Devices  page.
    Pavan
  • 3.  RE: CPPM Missing Configuration --> Security
    Posted Jun 16, 2017 08:41 AM
    I did a few Google searches and would not doubt I did not find the right information.
    I have never set this up before.  Could you send a link to the instructions, please?
  • 4.  RE: CPPM Missing Configuration --> Security
    Posted Jun 16, 2017 08:18 AM
    Why are you pointing ClearPass to another RADIUS server?
  • 5.  RE: CPPM Missing Configuration --> Security
    Posted Jun 16, 2017 08:43 AM
    We are updating a feature on our public captive portal page to allow subscribed customers to login and get additional options.   The customer's information is kept on other servers and not within ClearPass.
  • 6.  RE: CPPM Missing Configuration --> Security
    Posted Jun 16, 2017 08:46 AM
    Configuration > Authentication > Sources > Add, choose RADIUS as the type.
  • 7.  RE: CPPM Missing Configuration --> Security
    Posted Jun 16, 2017 08:58 AM
    Okay, much thanks.   I am there.  I see where to put in the IPs to the RADIUS server, and that I have to get their "secret".
    Is there a document that explains the different settings and options?   I am not sure what all I need selected and expecially what Attributes to have.
