last person joined: 10 hours ago
CPPM not sending sponsor approvals
  • 1.  CPPM not sending sponsor approvals
    Posted Feb 12, 2014 05:58 AM
    Hello again friends,
    OK something really basic (I got tunnel vision at the moment)
    This is driving me crazy. :smileymad:
    Anyone had this issue where the sponsor activation email is not sent to the sponsor?
    Also email receipt is not sent to the self registered user?
    Test email works ok through the SMTP relay internal and out of the network
  • 2.  RE: CPPM not sending sponsor approvals
    Posted Feb 12, 2014 06:11 AM
    Look in the Application log on clearpass guest.
  • 3.  RE: CPPM not sending sponsor approvals
    Posted Feb 12, 2014 06:22 AM
    Checked in there - I had a FW issue and I got a change done, and the app log said conenction refused on test mails
    When I manually click on send a email receipt to guest, it works - do the screen shots look ok to you?
  • 4.  RE: CPPM not sending sponsor approvals
    Posted Feb 12, 2014 06:23 AM
    Sorry to be clearer = I had a FW change done to resolve the connection refused when emailing
    I no longer have this I can manually trigger mail in test or by clicking send user email reciept
  • 5.  RE: CPPM not sending sponsor approvals
    Posted Feb 12, 2014 06:24 AM
    Who is refusing the connection?
  • 6.  RE: CPPM not sending sponsor approvals
    I no longer get this error since I had a FW chagne done
  • 7.  RE: CPPM not sending sponsor approvals
    Posted Feb 12, 2014 06:25 AM
    Awesome.  The screens look fine.
  • 8.  RE: CPPM not sending sponsor approvals
    Posted Feb 12, 2014 08:43 AM
    thanks for the sanity check :smileywink:
  • 9.  RE: CPPM not sending sponsor approvals
    Posted Feb 15, 2014 02:04 AM
    I got to to the bottom of it. My cluster is split between internal and DMZ. My SMTP relay is the problem. I can't use the same SMTP relay IP address or fqdn address. Long story but, so as I can only use a single SMTP address within the cluster I will be taking advantage of split DNS and getting the same CNAMEs added in internal and external DNS that reference different A records. This allows for the DMZ cppm servers to relay mail to a different target to the internals So the sponsorship confirmation and SMS stuff completes, also if the referenced A record is changed it doesn't matter as I am using CNAMES. Just thought I would mention this in case anyone has the same problem I was scratching my head about this for a while! Cheers ;)
