CPPM OnGuard VIA Integrated VPN - WebAuth Not Working
  • 1.  CPPM OnGuard VIA Integrated VPN - WebAuth Not Working
    Posted Feb 07, 2017 03:23 PM
    I'm setting up OnGuard-integrated-with-VIA agent to connect VPN to Aruba controller and do authentication and health check. I have the VPN portion working but the Health Check says "Authentication failed" with no other details. However, when I connect that machine directly to the corporate network it does an OnGuard webauth and is able to checkin correctly.  Why is it not working?
  • 2.  RE: CPPM OnGuard VIA Integrated VPN - WebAuth Not Working
    Posted Feb 10, 2017 05:06 AM
    Do you see "Authentication failed" in the access tracker?
    When your VPN is connected are you able to browse to the ClearPass web console?
  • 3.  RE: CPPM OnGuard VIA Integrated VPN - WebAuth Not Working
    Posted Feb 10, 2017 08:47 AM
    It turns out I had missed the Global Agent Settings for OnGuard where you have to say "Enable to install VPN component = True".
