cppm Palo alto interaction - a question
  • 1.  cppm Palo alto interaction - a question
    Posted Jun 29, 2020 12:24 PM
    CPPM 6.8.x  Palo Alto  Appliance  O/S  9.0.8
    When reading document "ClearPass_Integration-Guide_Palo-Alto_v2019-02.pdf", am i right in thinking that if you have a panorama system and some firewalls, you only have to send post auth data to panorama and it will forward "stuff" to  the firewalls ... as per the paragraph ...
    "Adding Palo Alto Networks Panorama Context Server Endpoint"
    Palo Alto Networks Panoramam is the centralized management system for the next  generation Palo Alto Firewalls. ClearPass has an option to integrate directly with Panoprama which in turn will forward the information to multiple firewalls it manages
    I only ask because in the attached diagram from a PA doc it implies that data is sent to a firewall whiich oin turn goes up to Panorama and then down to any other  firewalls.
    I've just created an enforcement profile I use in existing policies
    Rgds
    Alex
  • 2.  RE: cppm Palo alto interaction - a question
    Posted Jun 29, 2020 08:08 PM
    Yes, send the post-auth data to Panorama and it will forward the information to multiple firewalls it manages.
  • 3.  RE: cppm Palo alto interaction - a question
    Posted Jul 04, 2020 01:32 AM
    Hey Alex,
    Not sure if you saw the latest Blog I posted on July 1st of the latest and updated Exchange integrations, but we also posted A LARGE update to our CPPM/PANW Integration TechNote.
