My cppm 6.7.4 cluster shows the following list of patches installed. I would have thought it should only show the 6.7 patch list and not others such as the mysql driver and 6.6 patch list.
If you click in the list on 'Installed', you will see the progress screen for that patch. Then click 'Clear & Close' and the entry will disappear from the list.
You can do this for each patch that was installed and you don't want to see anymore.
Cool! didn't know that, many thanks. Pity I have to go round 8 servers to clear them out though :-(
Rgds
Alex
