CPPM Postgres TLS Settings
  • 1.  CPPM Postgres TLS Settings
    Posted Jan 30, 2020 02:05 PM
    Our checkbox enforcers InfoSec folks have determined that we must restrict TLS to v1.2 and I'm unable to find a setting for the postgres listener on 5432/tcp. I've played with the Disable TLS version 1.0/1.1 cluster-wide parameters in my lab (running v6.7.8), but I'm still seeing TLSv1.1 in my scans (sslyze --regular --starttls=postgres <pub>:5432).
    Is there a way to manage the TLS settings for postgres?
  • 2.  RE: CPPM Postgres TLS Settings
    Posted Feb 10, 2020 02:06 AM
    I'm not aware of such an option be available to the end user.
    However, I pretty sure TAC can login to the database with admin acces and set the SSL requirements.
    Not sure if they will comply to your demand though
    Good luck
  • 3.  RE: CPPM Postgres TLS Settings
    Posted Apr 28, 2021 06:59 PM
    Were you ever able to resolve this?  Infosec is flagging me for the same TLSV1.1 and I'd like to disable it.
    C
  • 4.  RE: CPPM Postgres TLS Settings
    Posted May 04, 2021 11:09 AM
    At least in CPPM 6.9.5, I see TLS 1.1 is not allowed. You may consider upgrading, or work with Aruba Support.
     * TLS 1.0 Cipher Suites:
         Attempted to connect using 80 cipher suites; the server rejected all cipher suites.
     * TLS 1.1 Cipher Suites:
     * SSL 3.0 Cipher Suites:
         Attempted to connect using 80 cipher suites; the server rejected all cipher suites.​
