CPPM radius authentication failed with controller 7010
  • 1.  CPPM radius authentication failed with controller 7010
    Posted Feb 25, 2015 05:11 AM
    Hi All,
    Radius athentication failed between CPPM and Controller 7010. But same configuration applied to Controller 3400 and it works fine.
    Attachment as below.
    Attachment(s)
    txt
    New-Controller-7010.txt   29 KB 1 version
  • 2.  RE: CPPM radius authentication failed with controller 7010
    Posted Feb 25, 2015 05:27 AM
    For first pic: modify your service, the req is not hitting your Service. [could you post your service summary]
    In 2nd pic its looking like you are testing your controller internal DB, make sure the user is in your internal DB.
    Edit: If you want to test CPPM from there, select CPPM ip from drop down and make sure the user is in CPPM's local DB.
  • 3.  RE: CPPM radius authentication failed with controller 7010
    Posted Feb 25, 2015 06:01 AM
    The authentication check on the controller will never pass in ClearPass. If it fails, that's a good sign. If you get a timeout, you may want to check connectivity.
    Tim
