CPPM Radius Dictionary
This thread has been viewed 23 times
  • 1.  CPPM Radius Dictionary
    Posted May 24, 2022 12:08 PM
    Hi
    I am encountering a problem with the purchase of Legrand brand PDUS as I cannot find the radius dictionary for the Legrand or Raritan vendor (the MAC of the device is 00:0d:5d:xx:xx:xx:xx).
    Exactly: Model 6 460 13
    My attempts to modify the xml have been null, I cannot perform a Whireshark as I am not "close" or capable equipment so I cannot analyze the flow.
    Any idea other than logging in with local user?
    thanks in advance
    Sanchez Lopez
  • 2.  RE: CPPM Radius Dictionary
    Posted 29 days ago
    Do you have the User/Admin Guide for this product? Check in there if RADIUS/TACACS is supported for login. It starts by enabling RADIUS or TACACS on the device, and the user manual should cover RADIUS / TACACS attributes if supported. You may not need a RADIUS dictionary as many devices will use the standard IETF attributes. You could create a service matching this device's authentication traffic, from there find out the device is sending. You can even do a packet capture on ClearPass with the 'Collect Logs' feature.
  • 3.  RE: CPPM Radius Dictionary
    Posted 28 days ago
    Hi Herman!
    You gave me an idea and I tried again today capturing, checking Radius IETF and Legrand/Raritan support.
    I found a way by applying an "Enforcement Profile" per role with the attributes:
    Radius IETF > Filter-Id > Raritan:G{Admin}
    Radius IETF > Filter-Id > Raritan:G{Operator}
    Thanks for your help.
