Thank you for your reply.
I need to configure a SSID in the Aruba controller where users will be redirected to a captive portal inside CPPM to enter user and pass. To make it I understand that I have to:
- Creat a Captive Portal auth profile
- A server group
- Configure inside server group a Radius Server (CPPM)
- An user role
- A captive portal aaa profile
And at the end, associate all this profiles and roles to the SSID created on the Aruba Controller.
(Correct me If I'm wrong)
I need to know the configuration flow to configure the CPPM, I need that:
- Captive portal configured inside it.
- Controller association
- Once the controller init the authentication with its radius server (CPPM) and users have entered their credentials, I need that CPPM check this user/pass against an external LDAP server.
