CPPM REST API question:status 403,"detail": "Access denied"
  • 1.  CPPM REST API question:status 403,"detail": "Access denied"
    Posted Jul 13, 2018 02:59 AM
    cppm version is 6.6.8. I test the REST API step by step from the document "ClearPass REST APIs.pdf".  In the lab, I can get the bearer code, and test the privileges API success.
    curl -X GET "https://172.16.6.137/api/oauth/privileges" \
    -H "Accept: application/json" \
    -H "Authorization: Bearer 99be2c41d05f6bda5b6011d7d23baa83d5fa1bc6" \
    -m 30 \
    -v \
    -k
    return:status:200.
    But I try to test API for query some MAC in endpoint, it's wrong.
    curl -X GET "https://172.16.6.137:443/api/endpoint/mac-address/005056a24df1" \
    -m 30 \
    -v \
    -k
    return:
      "type": "http://www.w3.org/Protocols/rfc2616/rfc2616-sec10.html",
      "title": "Forbidden",
      "status": 403,
    What's the problem? Somebody can help me?
  • 2.  RE: CPPM REST API question:status 403,"detail": "Access denied"
    Posted Jul 13, 2018 03:01 AM
    The operator profile doesn't have the correct permissions.
  • 3.  RE: CPPM REST API question:status 403,"detail": "Access denied"
    Posted Jul 13, 2018 03:12 AM
    I use the operator IT Administrators profile , it also wrong.
  • 4.  RE: CPPM REST API question:status 403,"detail": "Access denied"
    Posted Jul 13, 2018 03:14 AM
    Test with super administrator and see if it works.
  • 5.  RE: CPPM REST API question:status 403,"detail": "Access denied"
    Posted Jul 13, 2018 03:36 AM
    yes, successful. I find the wrong: the role of my local user is different from the operator role.
    THANK YOU!!!
    Request URL
    https://172.16.6.137:443/api/insight/endpoint/mac/111111111111
    Response Body
      "mac": "111111111111",
      "ip": "",
      "user": "test",
      "domain": "",
      "roles": null,
      "spt": "UNKNOWN",
      "device_category": "",
      "device_family": "",
      "device_name": "",
      "is_online": false,
      "updated_at": "2018-07-12T18:57:19+08:00"
    Response Code
    200
  • 6.  RE: CPPM REST API question:status 403,"detail": "Access denied"
    Posted Aug 03, 2018 01:48 AM
    I am using CP 6.6.7.
    When i am trying to connect with the API i receive a error 403 (using default API Guest Operator)
    When i am using the Super Administrator profile it is working.
    Does someone has a suggestion?
